DVD Studio Pro 4.0 question at DVinfo.net
Old September 13th, 2007, 03:12 PM   #1
Hello Everyone,
I´ve got a quick question...maybe not that quick actually.
I´m trying to make a menu, but its turning out to be more complicated then i expected. This is the effect I´d like to achieve...
I have 6 video clips. In this menu, I´d like to have the six tracks listed and a video that plays in the menu. The menu would start with track one highlighted and the video showing track one. As soon as a track 2 is high lighted the video would change and correspond to the selected track. Is this possible?
I appreciate any help, thanks a lot
John Stromme is offline   Reply With Quote
Old September 15th, 2007, 04:44 AM   #2
Originally Posted by John Stromme View Post
Hello Everyone,
Do you want motion, or just a static preview of the track contents? And do you actually want to play the video in the menu, or just a 20-30 second preview of video as you high light each track.
Grant Harrington is offline   Reply With Quote
Old September 16th, 2007, 08:17 AM   #3
If I read correctly, it is possible, but it's a bit tricky!
The way I would do it would be to create 6 different menus - one for each video clip. You just set it so that when you press the down/up arrows, it loads a different menu. Not sure how well it will look - the DVD player might pause a bit too long for your liking when you're navigating around the menu.
You would use this kind of technique:
http://www.kenstone.net/fcp_homepage...back_menu.html
Give it a shot, and see how it goes...
As far as I know, there isn't an easier way to do it...
Chris Hocking is offline   Reply
