#46 |
I agree, DVD-R are much more "universally compatible" with many many players as compared to +r. Also, I find Taiyo Yudens the absolute best blanks on the market. Their watershield glossys are fantastic.
HVR-A1u,WCS-999,HVL-20DW2 w/diff,2xAudio-Technica Freeway 600,Flycam 3000,Vegas 7E |
#47 |
Anyone had experience with authoring a DL disc and sending it off to discmakers or another reputable replicator and having problems in the finished replicated DVD-9 disc? They will except a DL master disc and will replicate that way in lieu of DLT tape. They claim that whatever is on the master disc is what will come out. I guess my real question is, is the problem that everyone has with DL disc the dvd player compatibility or the media itself? Will a replicated disc from a DVD+/-DL disc have the same compatibility problems?
#48 |
I doubt it. They are complaining about the media, not what is on it, if you are following the spec.There is a small chance that you might be bumping up against the MPEG-2 bit rate ceiling (9800kbps) in which case the DVD player might skip a beat, but other than that I would suspect the media.
#49 | |
The ability for a +R to behave as a DVD-ROM by setting its booktype should make +R much more compatible in older players. I had a lot of trouble with DL, either +R or -R until I settled on a good writer. My Sony, NEC and , worst of all, a SATA Plextor 755A all had trouble producing a DL without errors during verification. I've had zero trouble with write errors using Verbatim DVD+R DL on a BenQ DW1655 and DW1670 as well as a decent write speed at 6x. Now, playing that same disk on various DVD players is another story. As for your bride's manhandling of your disks, it is entirely possible that the DVD player is killing it (caught in multidisk changer) or that she is storing the disk on a surface that is causing scratches, both of which aren't active damage. So, she blames you. I used to think it was ok to keep a DVD on paper on my table until I lost a very important disk. |
