#16 | |
Also, PP 1.5 is Premiere Pro 1.5. Thanks. |
#17 | |
Stereo Effects
I suppose I was trying create an other-wordly feel with the stereo effects. Plus, it's a dream, so not everything makes sense. |
#18 |
I seem to recall they were triple points if we used the dreaded cell phone...
I liked it too. It's pace and lack of motion in some scenes remid me of those bad Sci-Fi films on late at night or on slow Sundays on the Sci-Fi channel. Some of those things, like when they are waiting for a monster to pop out of a closet or something, seem to take a bit too long to happen. That would be a great thing in a spoof of Sci-Fi. I'll have to remember that. I could also see the matte work in the initial mirror and later scenes. The concept was good however. I think there is an auto-match in Premiere that might have helped with the color and luminance balance to get the two overlapping images to look better. Also, if you have the option, use a soft border. It will disguize the edges much better. I try to use wipes to do a simple split screen. Sometimes you have to use a diagonal or other odd pattern to do it, like I did in mine. You might also be able to create your own wipe patterns from a mask, like they do in some aftermarket plugins. You could actually draw your shape in photoshop, import it and use it as a wipe pattern and still use a soft edge. Very similar to mattes. Overall, I like good B&W. If you had used a plugin to "age" it a bit, it would have had an old Sci-Fi movie feel to it even more. I like the flare for the stone. Sean McHenry
‘I don’t know what I’m doing, and I’m shooting on D.V.’ - my hero - David Lynch http://www.DeepBlueEdit.com |
#19 |
Quicktime Version
OK, here's a Quicktime version (as promised). At 59 MB it's still a bit large. It took me 5-10 minutes to download with a cable modem. I'll see if I can generate a smaller version without scarificing too much
http://slygo.com/vids/dreamstone000.mov Also, here a 19 MB Windows Media Version. The sound quality is off just a bit, but it's not too bad, I guess. http://slygo.com/vids/ds19.wmv |
#20 | |||
#21 | |
#22 |
I used the Color Corrector in PP for most scenes in Burnt. And despite having the same lighting and positions, even with identical Color Correction settings the matted mirror didn't match. But a bit of tweaking fixed it. It did make a few outdoor bits grainy though - should have just over-exposed the sky to start.
I generally play with the contrast, brightness, contrast centre, sometimes the gamma, and also modify the colour curves. All within the CC filter. But it does take a fair bit of playing around, and I often find it hasn't improved things a great deal. After effects gives you more per-channel control, but takes even longer again. Though you can really enhance the contrast in areas you want if you know what you're doing - pity I don't. To get any more sophisticated you'd need to do a blue/green screen for one version of yourself overlapping the other, but the lighting would get almost impossible to match. Cutaways would have helped with the jump cut, and only show one version of you. I know I found out the hard way, you can actually show (a lot) less and still illicit the same imagery in the viewer. And in my case probably not bore them as much. Aside from the harsh edges with the (I'm guessing 4 or 8 point garbage) matte it worked pretty well. Why it doesn't offer soft edges I don't know. You only learn by doing it, and then wish you knew what you now know before you started. |
