Text box only at DVinfo.net
Go Back   DV Info Net > The DV Info Network > DV Info Net Announcements
Important news relating to the DV Info Net site and these message boards.
Old November 11th, 2019, 05:29 AM   #1
Text box only
Hello all,
I tried to post a video in the "show your work" forum after reading the how to's. All I get is a text box and pasting a YT URL into it reveals {url] link [/url} the { & } so it doesn't show up as a link.
Under the text box I see;
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may edit your posts
BB code is On
Smilies are Off
[IMG] code is Off
HTML code is Off
Some forums have a post 10 before you can do certain things does that apply here. I did try the FAQ's but couldn't find anything.
Cheers
J.M. Read is offline   Reply With Quote
Old November 11th, 2019, 08:40 AM   #2
Re: Text box only
J.M., the system should automatically parse a YT URL and embed a player.
The shorter YT "share" links generally work better, but the full YT URL should do the job too.
Make sure it's just the link with no embedding code or anything else.
Can't show you here as this is the Announcements board where video embedding is turned off intentionally.
Please try it again and contact me by email (chris at dvinfo dot net) if it's still not sorted out.
Old November 11th, 2019, 09:56 AM   #3
Re: Text box only
Thanks Chris,
Email on the way with a couple of screenshots.
Cheers and many thanks - J
  You are here: DV Info Net > The DV Info Network > DV Info Net Announcements
