#61 |
Can not Private Message
I can not Private Message. Someone recently sent me a PM, and I could not see it. I checked my Control Panel, and there is nothing there for PM'ing. I clicked on a link about PM'ing, and the message said that I was not allowed to PM. Can someone turn PM'ing on for me?
#62 |
Hi Kip, I received your email about this as well. There's nothing wrong with your account. DV Info Net doesn't use a PM (Private Messaging) system. Whoever said they "sent you a PM" most likely sent you an email. If you've set your profile to receive emails from other members (Controls > Edit Options), that will allow DVi members to contact you via the email address you used when you registered here. Hope this helps,
#63 |
Actually I'm trying to empty out that so-called "main" category so we can get rid of it. There's enough (well almost enough) sub-fora within that section to handle just about any support-related topic. Once those posts are moved (it's not exactly high priority) then that area will no longer house any posts at all... it'll just hold the respective camera support sub-sections where any given post should go in the first place. Hope this helps,
#64 |
See attached screen grab (click to make it full size)
#65 |
OK thanks. I see now that the NoSpam question is only available in the Advanced Search page. When you click the SEARCH button at upper right, you get a screen that looks like this (attached). There isn't a "NoSpam" question in that dropdown. I'm using FireFox, so maybe that is the difference.
#66 |
Serious hiccup, after a long delay in refreshing. Tim Dashwood's last post in this thread: http://www.dvinfo.net/conf/jvc-pro-h...ml#post1010955 just got repeated multiple times.
Poor Tim... |
#67 |
#68 |
Latest advertising excess detroys DvInfo for me
I have been reading here for years and just recently registered. Now I am wondering if that was wise.
I have been away for a couple weeks and just now tried to read posts here. All I could see was this message on a gray background: "Sorry, you must have javascript enabled to view this site." This appears to be caused by some code to add a banner ad at the top of the page. I suspect this was some idiotic marketing excess just added by the advertising company. I note that in the comments in the page code it says this: * If you do not want to deal with the intricities of the noscript * section, delete the tag (from <noscript>... to </noscript>). On * average, the noscript tag is called from less than 1% of internet * users. So if you do not wish to force all your users to use an inherently insecure method of viewing you site (somethng I personally will not do), it looks like the offending code can simply be deleted. Please consider this ;-) -Mike |
#69 |
Mike -- what browser and operating system are you using? Thanks in advance,
#70 |
Website is getting slower, and slower, and stopping
Hi Chris:
What's with the website lately ? I am using IE 6 web browser and it just gets really slow, then grinds to a hault and stops dead. Why ? I switched over to latest FireFox, but there is no difference. Same problems. |
#71 | |
My OS
Thanks for responding. This has always been a first class, well run site, thanks to your efforts.
At the moment: Opera - Version information Version 9.52 Build 4916 Platform Mac OS X System 10.4.11 The code tries to do browser sniffing, but it only looks for IE and Mozilla (not very sharp). But I don't think the individual browser is the problem. The slowness mentioned by some users could also be caused by this code, which appears to be loading ad banners from a third party site. It is fairly common for such sites to get overloaded during peak times, and since the ad banner is first on the page this will often keep the entire rest of the page from loading as well. You may have the fastest servers in the known universe, only to have them defeated, held hostage by these third party ads... Which is something of a problem on an active discussion site. Solutions: Removing the noscript portion of the Javascript as the comments in the code suggests should fix the site unusable without Javascript problem.You could put a static ad from a sponsor between the noscript tags instead, which would display when the user had javascript off. To fix the slow loading problem: 1. Rewrite the page code so banners do not cause the rest of the page to wait until they load. 2. Consider using only static ad banners with fixed sizes. 3. Consider the fact that this is a specialized site with a high percentage of moderately or highly technical users, many of whom are pretty happy to support your sponsors and may just be annoyed by random banner ads. (I can't see them, so do not know how random they are, but that is the usual reason for such code). I can and do support your sponsors, and need no banner ads to do that. On the other hand, advertisers who slam animated flash ads in my face, bounce them over pages, pop them under browser windows, and engage in other such useless excesses (see: banner blindness) go on a blacklist and will never see a dime from me. -Mike Last edited by Mike Demmers; February 14th, 2009 at 06:45 PM. |
#72 | |
We moderators (some PC, some Mac, all browsers represented) collectively haven't had any problems since then, except some behind the scene functions that are always a little laggy. As many of us do, you've obviously got strong feelings about certain types of advertising but, sorry, the tirade about pop-overs etc is out of line. When is the last time you saw something like that come from DVinfo? NEVER. Chris can certainly speak for himself and probably will add to this, but I can tell you unequivocally that he is VERY sensitive about achieving balance with the advertising presence on his web site. He meets everyone face to face before he accepts their sponsorship, and turns a lot down. Whether one likes advertising or not, whether one would do business anyway with a particular sponsor or not, ads keep the lights on here. No ads means no DVinfo, in all its FREE glory. I'm sure Chris and Jeff will take your comments to heart and make tweaks if in fact there are tweaks to be made, but I felt I had to say my piece because the type of intrusive advertising you're writing about (bouncing ads, pop-unders) is not associated with DVinfo and nobody should be confused about that.
Pete Bauer The most beautiful thing we can experience is the mysterious. It is the source of all true art and science. Albert Einstein Trying to solve a DV mystery? You may find the answer behind the SEARCH function ... or be able to join a discussion already in progress! |
#73 | ||||||
We have a single ad position (top right) that cycles some flash or animateds, and right now you can count those on less than one hand. Compared to other sites in this particular market, we're one of the most if not the single most conservative in that regard. Quote:
DV Info Net is tested for FireFox, MSIE, Safari and Chrome. When more people are using Opera or one of the other 50-odd other browsers out there, then we'll test for it too. |
#74 |
Re: Various comments
Sorry if I got a bit into rant mode there. You did not deserve that - this just happened to be te last in a series of similar frustrations. And I don't have a dog... ;-)
My only real concern is that suddenly a great site that I have been using for years just fine without javascript is not allowing me to fully access it anymore. And this appears to be just from some code in the ad loading portion. I guess I was not very clear - this is not a browser problem. I see the same result whether I use Opera, Firefox, or Safari. On Mac and on Windows both. It is purely due to the Javascript. I have no problem with normal banner ads such as you always had in the past, I even suggested a place to substitute one. I was (over) reacting to what I thought might be a change in your policy that regard. When I said I needed no banner ads to support your sponsors, I did not intend to imply that I thought you should remove them. I do understand certain realities. Because of some very nasty stuff I have seen pushed out from some advertisers (on other sites ) in the past, I thought it might be the case that you did not KNOW what was in some of what was going up. So most of the remainder was me just guessing about some things and looking for a possible solution. I am very happy to hear your previous sensible advertsing policy is unchanged. Now I would just like to access the site as I used to, if that is possible. I'm pretty sure a small change in the noscript portion of your page code will fix this. |
#75 | |||
