Secrets: DV Challenge #2 - Page 2 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > The DV Challenge
The DV Challenge
An organized theme-based competition where Content is King!
Old July 25th, 2005, 12:24 PM   #16
Originally Posted by Craig Bellaire
I think this just might be the first short I've seen shot on the famous PDX-10. I actually have one and the hard edge of the PDX-10 isn't apparent here. Nice work.
Two or three of the others were shot on the PDX10 as well, including my own shameful little bit.
" When some wild-eyed, eight foot tall maniac grabs your neck, taps the back of your favorite head against a bar room wall, and looks you crooked in the eye, and he asks you if you've payed your dues, well, you just stare that big suker right back in the eye, and you remember what old Jack Burton always says at a time like that, 'Have you paid your dues, Jack? Yes sir, the check is in the mail."
Michael Gibbons is offline   Reply With Quote
Old July 25th, 2005, 03:44 PM   #17
I didn't kill all the detail as some folks do but I do believe I set it down at least 1 notch before I do anything. Also, the compression does a real number on the sharpness. I dropped the frame rate to 15 for both online versions.
I plan on adding one of the missing shots tonight. At least work in the missing shot of the answering machine from which we hear the husbands VO. Some folks thought it might have been a radio initially. I should have EQed it a bit tighter I suppose but with the visual, people will put that together easily enough.
I have always shot in 16:9 also. Makes for a rough workflow to DVD some times but I like it. Plus, we have a Plasma on the wall in the living room and it just looks so nice to fill the screen. As a side benefit, it teaches you to use a full film frame.
Sean
‘I don’t know what I’m doing, and I’m shooting on D.V.’
- my hero - David Lynch
http://www.DeepBlueEdit.com
Sean McHenry is offline   Reply With Quote
Old July 27th, 2005, 12:47 AM   #18
Made one minor alteration to the non-contest, almost final version. You can see the slightly reworked version by clicking the versions in the right column on the web page at http://www.surgetechservices.com/smchenry/
I will be adding one more shot and some VO and it should complete the piece to my satisfaction and make a few issues clearer.
In this version I simply added the announcement from an answering machine before the first VO. It should be more apparent now that this is a pre-recorded message left by phone. I was originally going to add a shot of a finger hitting the play button but it would have disturbed the original flow that I liked so much.
More in a day or two.
Sean
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > The DV Challenge
