iFootage Shark Mini Complete at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old November 14th, 2017, 10:10 AM   #1
Sponsor: Camera Motion Research
We have the iFootage Shark Mini Complete in stock.
It's lightweight with tool-less set up and a backpack for portability.
3 axis motion control using any iOS device (android coming) for manual or programmed operation.
http://www.camotionllc.com/shark-mini/
Rich Greb
Rich Greb is offline   Reply With Quote
Old November 16th, 2017, 04:12 PM   #2
Re: iFootage Shark Mini Complete
Hi Rich,
By 3-axis control I assume you mean travel along the rails plus pan and tilt, is that correct? One of the control icons indicates that gentle stops and starts will be possible. Do you have figures for the range of rates of pan, tilt and travel?
Old November 17th, 2017, 12:11 PM   #3
Alastair,
Yes, travel, pan and tilt control.
You can control the start and stop speed (ramping up and down). See the attached image.
Slide speed is adjustable from .1mm/sec up to 50mm/sec.
Pan and Tilt speed is adjustable from .1 deg/sec up to 30 deg/sec.
The distance you are able to travel first has to be input on the number of tracks you're using (total length), and then you can start and stop anywhere within that length of track.
Perhaps the best way to learn more about the Shark slider mini is to download the free app in the app store. Just type in "ifootage moco". Once you've downloaded it and registered you can press on the question mark in the bottom right hand corner, and it will bring up tutorial videos for you to watch.
Rich Greb
CMR
iFootage Shark Mini Complete-243445637565.jpg   iFootage Shark Mini Complete-wqe.jpg
Last edited by Rich Greb; November 17th, 2017 at 12:12 PM. Reason: correct spelling of Alastair
Old November 17th, 2017, 10:27 PM   #4
Hey Rich,
Is there any way that the iPhone interface will work with my iFootage S1A1 Wireless Motion Control System for S1 Shark Slider?
Best,
Michael Stevenson
Michael Stevenson
Michael Stevenson is offline   Reply With Quote
Old November 18th, 2017, 06:30 AM   #5
Hi Michael,
Not at this time. IFootage has an iPhone (and Android) interface for the Shark motion control systems in the development pipeline. A release date for these is not available yet.
Rich Greb
CMR
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
