Kessler Basic Controller... at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old January 18th, 2016, 11:44 PM   #1
Hey guys, simple question... does anyone know if I can power the Kessler Basic Controller (Kessler elektraDRIVE BASIC Controller) with this v-lock battery (V-Gear VG-130S Hi-Performance Li-Ion Camera Battery - Jetlinks) using a d-tap to DC cable?
I don't have a technical enough background to know if the power ratings on both accessories are okay with each other.
Cheers,
Rob 🍻
Robert Davies is offline   Reply With Quote
Old January 20th, 2016, 07:56 PM   #2
Re: Kessler Basic Controller...
For anyone's who's interested, I also chased Kessler on this and got a reply:
You should not have any problem using the d-tap to 12VDC barrel cable as long as your battery meets these specs:
- 11.9VDC to 15VDC
- 4.16 amps (minimum)
Hope this helps, let us know if you have any questions.
No need to go and buy additional batteries after all... 👍
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
