Good ball head for DP Slider at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old November 18th, 2011, 11:56 AM   #1
Grabbing a DP slider over the holidays, and I need some advice on what heads you guys are using for this.
Must be able to support a 7D, with grip, and a 70-200. Guessing a Manfrotto 498RC4 would be acceptable?
http://www.bhphotovideo.com/c/product/660312-REG/Manfrotto_498RC4_498RC4_Midi_Ball_Head.html
Any other recommendations?
Justin Molush is offline   Reply With Quote
Old November 18th, 2011, 07:36 PM   #2
Re: Good ball head for DP Slider
I don't use a ball head instead I use this fluid head.
http://www.bhphotovideo.com/c/product/553854-REG/Manfrotto_128LP_128LP_Micro_Fluid_Head.htmlThey also have one with a QR plate
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old November 18th, 2011, 09:06 PM   #3
My main concern is being able to adjust for angles. I plan on running the slider on 45* downward slides to emulate a little bit of a jib motion. That head doesn't allow for an angled adjustment which is why I was thinking ball head.
I do have a tripod but it is a 65mm bowl head and I dont think there are any sliders that can make that work.
Old November 18th, 2011, 09:20 PM   #4
Just mount the adaptor plate on the 7d sideways and you can use the fluid head for all sorts of angles.
That's what I do with an old Manfrotto 501 head.
Jerry Porter is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
