Slider Technique Advice Please at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old November 17th, 2011, 02:07 AM   #1
Hi All,
I have the Konova slider and it's great for the left to right shots, but I am having trouble with the back to front shots. I am using the slider with a Manfrotto 49RC2 and a t3i with battery grip so there is plenty of height. When I move my camera to the back of the slider the front of the slider comes into shot.
Opteka GlideTrack Test - YouTube this is the type of shot I am trying to recreate but I can only move the camera back around 5 inches before the slider comes back into frame making these kinds of shots impossible. Am I missing something?
Tariq Peter is offline   Reply With Quote
Old November 17th, 2011, 05:39 AM   #2
Re: Slider Technique Advice Please
Have you tried using a longer lens. By that I mean a longer focal length, although a physically long lens may also help!
www.mikemarriage.com
Mike Marriage is offline   Reply With Quote
Old November 18th, 2011, 07:44 AM   #3
Your best bet is to use a longer lens.
It sounds like you may be trying to get a wider shot than the dolly being in frame will allow, that is just physics.
Good luck
Gerry Gallegos is offline   Reply With Quote
Old November 18th, 2011, 08:17 AM   #4
I sometimes tilt the slider down in the direction of forward travel to frame out the track. Look at the title shot of this:
I also sometimes offset the slider so that I'm tracking in or out and an angle - again one can frame out the track.
There are some more examples of my slider technique here: http://vimeopro.com/robindr/camera-slider-videos
TV Director / Cameraman
Old November 18th, 2011, 08:45 AM   #5
there are a few possible work arounds, you can use longer lens, when on the ground i usually slightly tilt camera up, when on the tripod i slightly tilt slider down. great results using upside down setup, but it takes a lot more time and space to set up.
I love this place!
Buba Kastorski is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
