Laser pointer needed 4 Skater Dolly Setup? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old November 30th, 2010, 04:16 PM   #1
I have seen these laser pointers for adjusting the wheels on the PS-Technik & Omni-Tracker skater dolly, and the PS one has an up and down laster tilt adjustment whereas the Omni-Tracker does not, so how necessary really is a laser pointer for setup for just simple work, not Hollywood big paid gig type of work?
Dave -
Dave Allen is offline   Reply With Quote
Old December 1st, 2010, 02:46 PM   #2
you can find laser pointer as cheap key ring for less than 2$.
Old December 4th, 2010, 01:36 AM   #3
True, but then I have to make something to hold it to the wheel holder and I hate making anything without a lathe and mill.
Dave -
Old December 11th, 2010, 10:30 AM   #4
The anwser lies in the question whether you can make the right circle without the pointers.
The pointers just help to pinpoint the center of the circle.
Do your shots need to be this perfect?
Do you have time for trial and error when adjusting the wheels?
Can you afford it? (Or make a cheaper solution?)
I recently got a Hague Mini Table Dolly (a very simpel 'version' of the mini skaterdolly) and it takes some time to get the wheels in the right angle without pointers.
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old December 11th, 2010, 07:46 PM   #5
Well, I know the PS Technik skater also has an up and down pitch adjustment capability. I can't tell if the Omni-Tracker has that on their laser aiming thing.
Dave -
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
