Pocket Dolly Question at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old February 11th, 2010, 06:59 PM   #1
I recently got a Pocket Dolly from Kessler and I had a question regarding push ins/outs. I have a 5D Mark II mounted to it and when I attempt to place the camera for pushing in and out type dolly shots, unless I have it angled up really high or set at the maximum zoom (105 mm) you can see the silder in the shot. In other words I need a way to mount the camera at least a foot or more above the slider so it doesn't get it in the frame. Has anyone figured out a solution around this problem?
Dana Rice is offline   Reply With Quote
Old February 16th, 2010, 08:47 PM   #2
Sponsor: Kessler Crane
Hi Dana -
You can use the Flat Mount Adapter and flat mount a fluid head on the Pocket Dolly carriage and then your camera on the fluid head. That should give you the height that you need.
Kessler Crane™
Website | Facebook | Twitter
Chris Beller is offline   Reply With Quote
Old February 17th, 2010, 04:51 AM   #3
I've got the flat mount adapter and ..
Slik | 504QF-II Video Head | 618-504 | B&H Photo Video
cheap & does the job - I also throw the 701hdv head on for more complex moves
Cheers - Paul M.
www.perbenyik.com
Paul Mailath is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
