Using the Glidetrack for crane shots at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old February 4th, 2010, 08:40 AM   #1
Created this little teaser for the Glidetrack a week or so ago. I thought I would try some new moves (rolling, dolly shot) as well as see if I could use my GT as a crane... which you can.
Shot using a GT SD 1meter. I almost never use this one for weddings as the GT compact is all you need.
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old February 5th, 2010, 12:11 AM   #2
Looks good, what camera/lens did you use?
Old February 6th, 2010, 03:45 AM   #3
Well that's damn good mate...
I'm tryin to figure out how u can use GT as crane...but i can't!
How do u did?
Mark Adin is offline   Reply With Quote
Old February 6th, 2010, 06:43 AM   #4
That looked really good.
Chris McMahon is offline   Reply With Quote
Old February 6th, 2010, 07:02 AM   #5
Sponsor: Westside AV
You simply mount the track on a liquid head, it can then be spun and tilted.
The difference is that on a crane the camera is always level because there are two bars acting together to maintain level.
This is a little like using a pole with a pivot in the middle.
It can be used to great effect, but is not as versatile as a jib/crane. It helps to have a brake on your carriage for obvious reasons.
Olof
Reasonable Priced Sliders ? Westside A V Studios
Old May 12th, 2010, 09:38 AM   #6
Would someone be willing to post a video of how using the glidetrack as a crane is accomplished? I just got a glidetrack sd and am using a Manfrotto 501hdv. Seems like this would have to be a two-person technique. Also, it seems like the tripod head would be unable to get up to a 90 degree angle or higher.
www.clarkvideoproductions.com
Michael Clark is offline   Reply With Quote
Old May 12th, 2010, 10:01 AM   #7
Well, Alastair Brown is officially awesome. Not only was my tripod delivered in 1.5 work days (from SCOTLAND to Tennessee - how is that even POSSIBLE???), but I just wrote him an email regarding this issue, and he sent me a link within minutes. Here is his response:
Try fitting the rail to your current head at the end of the rail.
Fit a second head and then you can do up/down shots with a controlled arc.
Tips - Glidetrack Blog
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
