Introducing - DP Slider - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old January 27th, 2010, 04:30 PM   #16
Originally Posted by Don Pham View Post
how heavy of a camera would you like to support and slide smoothly?
Don,
I direct a daily soap produced by BBC Wales for S4C. Most of the shoot is studio/lot based, but there is a degree of location work shot single camera with a Sony DVW790.
I know it would be somewhat extreme on your basic slider, that's why I was thinking about ganging two together. It would still be cheaper than the other top-of-the-range alternatives.
Obviously, I'm only thinking about lateral tracks - not the vertical option...
Old January 28th, 2010, 10:17 AM   #17
200mm lens sounds very good.
I would use it with a shoulder ENG cams like 450 and the new 350 clean
or maybe a mattbox.
Do you think that if your slider supports the weight I could do vertical shots as well?
How difficult is it to do a clean vertical travel with some pan or tilt?
Love the verical option.
www.newshound.biz
Boris Barel is offline   Reply With Quote
Old January 28th, 2010, 02:05 PM   #18
Great choice of model on the video clip... :)
I was very interested in it being able to do vertical as well as horizontal slides. Will you be selling this slider via agents in Europe as well as USA/Canada?
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old January 28th, 2010, 03:30 PM   #19
Originally Posted by Robin Davies-Rollinson View Post
Don,
that must be cool doing a soap production. i did not target the eng market but if there is a need/want for my slider in that market, i will develope a slider for it. i am arranging a test run with a loaded Red One. the results/feedback will help me to understand and improve my sliders for bigger camera.
Don Pham is offline   Reply With Quote
Old January 28th, 2010, 03:34 PM   #20
or maybe a mattbox.
the slider should be able to handle the 350 as it is only 14 lbs.
the vertical shots is dependent on how good the operator is. the slider helps guide the camera verticaly but the pace and smoothness is operator dependent.
Old January 28th, 2010, 03:35 PM   #21
currently you have to order directly thru the website.
Old January 29th, 2010, 03:09 PM   #22
here is a pic of a EX3 on the slider from a customer
DP Slider: EX3 on DP Slider
Old January 31st, 2010, 12:50 AM   #23
How much weight can a DP Slider handle?
Instead of telling you, I want to show you.
The following was a 6.7 lbs V-1200 (47 inches) DP Slider put to the test.
DP Slider - take1productions' Photos
Old January 31st, 2010, 04:21 AM   #24
Thanks Don - I look forward to seeing the test results.
Old January 31st, 2010, 09:14 AM   #25
Okay.. I'm impressed!
Michael Dontigney is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
