Post pics of your homemade dolly's - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old June 3rd, 2005, 03:51 PM   #16
Yes good idea. You can brace your pvc with lumber, wood or timber, (depending on which part of the world you live.)
But. Have you tried the aluminium tubing used on scaffold towers?
It's light, strong and there is all sorts of gizmoes that come with it to brace the thing together.
Owen
Owen Dawe is offline   Reply With Quote
Old June 3rd, 2005, 09:04 PM   #17
I noticed you used both the track and dolly along with a wheelchair. Is one more useful then the other or are they equally important in getting a smooth shot?
Also...
This may be off topic, but I'd hate to start a new topic about this just to ask a small question relating to Jean's pictures.
What LCD monitor are you using in the pictures and are you satisfied with it? Could you give me a link to where I could purchase it? Any other comments you have about it?
I'm looking for an LCD monitor and throughout all of the threads concerning LCD monitors they seem to be widely varied.
Thanks a lot.
Travis Maynard is offline   Reply With Quote
Old June 4th, 2005, 08:10 AM   #18
Hi Owen,
I've used everything imaginable for dolly track, but unless you've got the sections machined just right, you'll get the tell-tail bump at the joined sections. That's why I like the pvc so much. It's just easy. I've been working madly to solve the problem for aluminum dolly track for my book buyers that doesn't require welding, beautifully machined edges, etc. So far, I've had the best luck with angle ('L' shaped) aluminum. You lay the open end on the ground to form a triangle, and the wheels ride at the point of the triangle (this is for my wheel design. not sure if will work for the typical skate board wheel design). With good edges, it becomes pretty easy to join, but I've got a lot more shooting situations to try it in before I'm sure it's a good, workable design.
Dan
www.dvcamerarigs.com
Dan Selakovich is offline   Reply With Quote
Old June 4th, 2005, 10:25 AM   #19
Travis,
The dolly with track is definitly smoother than the wheelchair. When the traveling is straight in line, I use the dolly. But when I need something different, a circular movement, or a long travelling forward (in which case, dolly's tracks could be shown on the screen) I use a wheelchair if the floor is smooth enough.
Regarding the monitor, it's a Varizoom 5.6".
http://www.varizoom.com/monitors/tft.php#theworks
Works great, good resolution, and the ultimate pack come with a lot of handy accessories (Battery, carraying case, hot shoe swivel, AC cord, charger, sun hood, rca cable, ... )
But it cannot be switched to 16:9. Beside that, it is good, and recommanded by Chris Hurd here: http://www.dvinfo.net/canon/articles/article79.php
Hope this help,
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old June 4th, 2005, 02:54 PM   #20
PVC is King!!
Here are the photos of my (DVcamerarigs I should say!!) dolly system. It;s still being "adjusted" (like the dolly is a bit small).
http://www.xlr.demon.co.uk/img/dolly0001.jpg
http://www.xlr.demon.co.uk/img/dolly0002.jpg
http://www.xlr.demon.co.uk/img/dolly0003.jpg
http://www.xlr.demon.co.uk/img/dolly0004.jpg
http://www.xlr.demon.co.uk/img/dolly0005.jpg
The PVC pipe is easy to work with. You can see from one of the photos that the join has a 10inch dowel which fits perfectly into the PVC pipe. As far as bumps go, this setup was on an uneven lawn and the only wobble was where I didn't level it (i.e. no problems with the joins). It's simple to level. Just stick bits of wood under the sleeper/timber until it's right. The sleepers and timber are the key to it being smooth (in my opinion). On a nice flat surface it works really well.
Declan Smith is offline   Reply With Quote
Old June 4th, 2005, 03:55 PM   #21
Jean,
I see. I plan on making a dolly much like yours very soon. Now, If I only had a wheelchair. ;)
About the monitor:
It seems like a very reliable monitor. One thing, you said it cannot be switched to 16:9. Does this mean it squishes the 16:9 image to 4:3 or does it add a letter box to it where other 16:9 monitors would just have it fullscreen 16:9?
Old June 4th, 2005, 06:08 PM   #22
Declan,
Very nice dolly! I think I'll build one just like yours. I like how you did the track and the wheels. It looks very portable in a truck or suv.
Thanks for posting the pics!
Eric
Eric Holloway is offline   Reply With Quote
Old June 5th, 2005, 08:01 AM   #23
Hey Declan,
Nice job! But I'm wondering why you didn't send ME these photos! ;=)
I'm working on a gallery for the web site for all the "Killer Camera Rigs" builders, so I'll grab these. At first I wondered why you didn't use the removable bracket system in the book that allows you to put the wheels on different sized platforms, then I noticed the UK url. Guess the brackets aren't available there. Hold on to the current size. It's great for things like dollying through a window! The Quicktime demo on DVcameraRigs.com where the dolly goes through the back seat of a car is only 12" square. Then we've got one that's 2 feet by 3 feet that's "rideable". The Killer Camera Rigs dolly is low cost enough, even using the angle iron system, to make several sizes for different shooting situations. Also, build the "Killer's Kiss Crane" to go on that thing! It's such an easy jib to make, and will open up a whole new world of shots.
Again, nice job!
Dan Selakovich
www.DVcameraRigs.com
Old June 5th, 2005, 03:33 PM   #24
Hi Dan
Thanks for your comments, and thanks for the great book!!
I have only just built this dolly, and did a post here quick. The photo's are still drying!! I will send you feedback direct on any future builds I do.
As for the removable wheels, if I searched a bit harder here in the UK I would have probably found the right brackets, however I had an old angle iron bedstead lurking behind the shed which I knew would come in useful! Incidently, if you look at dolly0003.jpg, you can see that you only need to unbolt one nut to get each wheel off and transfer it. As I still have 3/4 of the bedstead left, I planned to make up some more brackets if need be. (in hindsight I should have made the bracket smaller, which I will do for the next one).
Feel free to use the photos in your gallery. The next project is the crane, just as soon as I can source the bits. Also, what would be good is a stabalizer that can take the XL2 (which is a heavy camera for handheld use).....next edition maybe ??
Cheers
Declan
Old June 5th, 2005, 05:51 PM   #25
Travis,
Yes, it's a 4:3 monitor and it squishes the 16:9 image to 4:3. Personnally I am able to work with this, but it is nice to know it before the purshase. :)
Old June 6th, 2005, 07:17 AM   #26
Hi Dan
If you practice with the stabilizer just 10 minutes a day, I think you'll be surprised at how long you can go with a hand-held rig at the end of a month! But, yes, working on a full stabilizer rig for "Son of Killer Camera Rigs". It's been going through some improvements lately; like custom forming the vest EXACTLY to your body, and a fully customize-able sled. (I want to take full advantage of the fact that people will be building this themselves, FOR themselves). I hope to have the book out by Christmas. Very clever using an old bed frame on the dolly! Wish I'd thought of that!
Dan
Old June 6th, 2005, 09:59 AM   #27
A good choice, IMO, on the external LCD for dollies or cranes is a portable DVD player like the Centrios 7" shown here:
http://www.pana3ccduser.com/showthread.php?t=2694
It does 4:3 or 16:9 (7" 16:9 aspect LCD) and has AV inputs and outputs. It also includes a 2.5 hour battery (playing DVD's), 12V adapter and AC adapter. Cost for this one was $230 CAN, ($185 US)
Seconds as in-car entertainment for the sprouts.
Dennis Wood is offline   Reply With Quote
Old June 6th, 2005, 11:33 AM   #28
Dennis,
You are right, but it is less portable than a true portable LCD monitor, and you can't mount it on the camera for handheld work. Can't be mounted on a steadicam device too...
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
