What documents to help plan a documentary? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Documentary Techniques
-- Discuss issues facing documentary production.
Old February 25th, 2013, 01:28 PM   #1
Hi
In the process of planning a documentary.
So far I've got a document with a basic outline of projected deadline I want to get things done by. I've also got some storyboards and a document with my interview questions.
Is there anything else which can help me in the process of planning a documentary? (first time doing a project of this scale).
Ben Davies is offline   Reply With Quote
Old February 25th, 2013, 01:53 PM   #2
Re: What documents to help plan a documentary?
I always considered watching the National Film Board of Canada's interviews with 30 top documentary filmmakers a helpful activity before I undertook my own first documentary. YMMV
Playlist : Capturing Reality: The Art of Documentary - NFB
Old February 25th, 2013, 02:15 PM   #3
Cheers. Will rent it and check it out, anyone else got any tips?
Old February 25th, 2013, 04:44 PM   #4
As part of the process you should start thinking about what release forms you will want to use. You should get everyone thats appearing in your documentary to sign a relase form. If you are using photographs that you dont own, you will also need to have a release for those. The last thing you want to do is put together a really great documentary and then not be able to use portions of it. Also, you should consider getting anyone thats helping you film, to sign a document stating that all footage belongs to you and that you are the sole copyright holder. You may want to consider speaking with an attorney for addtional guideance.
Kevin Lewis is offline   Reply With Quote
Old February 25th, 2013, 07:12 PM   #5
It's online. No charge.
Old March 22nd, 2013, 07:02 AM   #6
Any interviews you do make sure you use some cut-aways shoots. Pick a topic what will interest the audience. Then again if the subject material is limited for example how to grow a lawn make it exciting to watch.
What subject are you planing to tackle?.
Frank Maxwell is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Documentary Techniques
