24 or 30P at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Documentary Techniques
-- Discuss issues facing documentary production.
Old September 28th, 2012, 07:56 PM   #1
24 or 30P
Hello,
I'm going to film a doc about my town. The main audience is a French TV called ARTE. They told me they don't care whether I film 60i, 24 or 30P, they have very advanced facilities that can process anything and conform it to the French and German system, since ARTE is Franco-German.
Now, to keep my options as open as I can, independently of ARTE, should I shoot 24P or 30P?
I'm using a NTSC canon XH-A1, I'm in the US
THanks
Larry Secrest is offline   Reply With Quote
Old September 29th, 2012, 11:26 AM   #2
Re: 24 or 30P
Larry I also own the XHA1. I ve had it for almost 4 years and have only recenlty started to explore the 24p option. I typcally shoot eveything 30p and I am very happy with the results. I think it depends on the look you want. If you shoot 24p just make sure that yiu have a good understanding of how the camera will perform with the various settings. I have experimented with the 24p option (hd) and like the results, but for some reason I am hesitant to use it for an actual production, i'm not quite sure why.
Kevin Lewis is offline   Reply With Quote
Old September 29th, 2012, 08:54 PM   #3
Re: 24 or 30P
Either 30p (29.97p) or 60i (59.94i) will give you the most options for delivery, in both HDTV and NTSC/PAL.
Old September 30th, 2012, 05:38 AM   #4
Re: 24 or 30P
Hi Sareesh,
In what way would 24P limit me?
Larry
Old October 1st, 2012, 09:27 PM   #5
Re: 24 or 30P
You can't go to 29.97 with 24p footage, without interpolation, and not many broadcasters accept such a conversion. Even if HDTV supports 24p, many broadcasters still prefer 30p, especially if they also want to broadcast in standard definition.
Therefore 29.97p is the 'safest' bet. Most prosumer camera sensor readouts are 60i anyway, and the conversion to 24p is done in camera.
Old October 4th, 2012, 03:47 AM   #6
Re: 24 or 30P
I would say your safest bet would be recording in 50p/60p full HD. This way you can downscale if the need arises. You can easily go from 60 to 24, but not the other way around.
Marius Tatarasanu is offline   Reply With Quote
Old October 6th, 2012, 10:30 PM   #7
Re: 24 or 30P
If that were true, they would never show Hollywood movies on TV. Nor would they have been able to shoot over 60 years of episodic TV shows on 35mm film.
It's a standard practice to slow 24 down to 23.976 and then insert 3:2 pulldown to spread 4 frames of film across 5 frames of video. It's not that hard to insert pulldown with After Effects or other software.
there's an explanation of pulldown here: Three-two pull down - Wikipedia, the free encyclopedia
Post production is not an afterthought!
www.arniepix.com
Arnie Schlissel is offline   Reply With Quote
Old October 7th, 2012, 06:10 AM   #8
Re: 24 or 30P
Hello,
THanks
Shoot the frame rate you feel renders your project in the best way. If you are accustomed to shooting 30p then shoot that.
There is no magic frame rate that makes your project more or less desirable to a broadcaster. If anyone rejects your project over frame rate it is an excuse to reject you but not the real reason.
http://www.LandYachtMedia.com
Old October 7th, 2012, 09:06 PM   #9
Re: 24 or 30P
You missed my words "without interpolation".
Old October 14th, 2012, 09:46 PM   #10
Re: 24 or 30P
No, I did not.
That is not correct. All US broadcasters will accept material that has been converted from 24p to 60i (or 30i in standard def) as long as it has correct 3:2 pulldown. the practice is very common, and is as old as television broadcasting.
www.arniepix.com
Old October 14th, 2012, 10:50 PM   #11
Re: 24 or 30P
You are right. I stand corrected.
Old October 21st, 2012, 01:11 PM   #12
Re: 24 or 30P
Thanks to all for the answers.
I'll go 24P.
Old October 21st, 2012, 09:36 PM   #13
Re: 24 or 30P
Is there a particular reason you want to shoot 24p? If you are going to film it makes sense. For TV it will always need to have pulldown to re syncronise with the refresh rates of the TV. Of course 24P can be shown on a 60 or 50hz refresh TV but then the frame rate is not 24P its a modified cadence to conform to the refresh rate of the TV. For NTSC that is most likely a 60hz and Europe 50Hz. Shooting for Europe this cadence changing will occur anyway from any of the NTSC frame rates. For Europe 25P would be a better choice. I am not sure if higher frame rates would provide more data for a conversion change.
Ron Evans
Old January 29th, 2013, 12:48 PM   #14
Re: 24 or 30P
Aesthetically, 30P or 30PN is more pleasing to look at when you pan fast right or left in the shot. There are simply more frames to fill. 24P or 24PN is more toward scripted and carefully planned shot where you have full control. You have to be extra slow and gentle with the pan left right w/ 24P, otherwise it's has a very jerky and studer look. In fact, I often shoot at 60P and conform it to a 29.97 fps time line when I need to have nice slow motion effect. If you do lots of wild life docs, most people use Phantom cameras and go as high as 120 fps.
It all depends your style of shooting for the docs. If you like conservative, locked down shot, 24P should work fine. But if you like fast zoom, pans and all sorts of movements, 30p is much better suited. 60i is just a bit too realistic for me. It looks like a live soccer or news type. Personally 30p is just right in between 60i and 24p.
Last time I check 99% of documentary I shoot has no such luxury of a staged, planned shot. It's literally news style w/ unpredictable pans, zooms at all sorts of speeds. I've shot docs in 30P and now 30PN since 2003 and never really stick to 24P. The key is to stick with the same format and try not to mix and match (especially w/ the ##Pn format).
Sam Lee is offline   Reply With Quote
Old August 2nd, 2013, 08:34 AM   #15
Re: 24 or 30P
I know this is an old thread, but I have to say you all forgot what Larry said: he shoots for ARTE, which is a French/German channel, they don't broadcast in 30/60! In Germany, they have a 50i SD channel and a 720/50p HD channel.
So 30fps would be the least viable option in my opinion.
And btw. what? ARTE wants to buy a whole docu from you? Larry, that would be considered a real honor in Germany (and I guess France too). People here would start conversations with that like "when I shot this docu for ARTE..." ;)
Heiko Saele is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Documentary Techniques
