Transcoding and rewrapping at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > divergent media ScopeBox and ClipWrap
The official support forums for divergent media's ScopeBox (video monitoring and recorder) and ClipWrap (m2t to .mov re-wrap).
Old January 22nd, 2011, 03:56 AM   #1
I'm a little confused - whats the difference between transcoding and rewrapping?
Do both keep the original timecode? What are the pros and cons to each?
Marty Jenoff
www.focalpp.com
Marty Jenoff is offline   Reply With Quote
Old January 22nd, 2011, 09:21 AM   #2
Sponsor: divergent media
We've got a blog post coming in a day or two at divergentmedia.com that goes in depth on this very subject, but in brief:
When rewrapping, ClipWrap leaves the video samples (the core video data) from the source untouched. It just rewrites the wrapper data, which tells QuickTime where to find each frame of data, what format it's in, etc. This means the rewrapping process is very quick (nearly as quick as copying a file).
For HDV content (M2T), this is fine, since Final Cut and other apps are well optimized for HDV-in-MOV. For AVCHD content, it's a bit trickier - because AVCHD is so much more CPU intensive to decode, apps like FCP don't deal well with it in its raw (rewrapped) format. It's fine for playback, but for serious editing the rewraps are a bit too demanding.
For those cases, there's transcoding. With transcoding, we decompress the video samples to raw, uncompressed video, and then recompress them using your selected format (Apple Intermediate, ProRes, etc). The workflow we generally recommend for FCP, FCE, iMovie, etc with AVCHD content is to transcode to Apple Intermediate, as it's a good balance between file size, performance, and quality (no quality loss from your original). Transcodes do take longer than rewraps though, since there's a lot more computation involved.
Hope that helps - otherwise, check the divergentmedia.com blog tomorrow or monday for a full, very nerdy writeup.
-Colin
Divergent Media Support
www.divergentmedia.com
Colin McFadden is offline   Reply With Quote
Old January 22nd, 2011, 09:22 AM   #3
Oh, also - all the settings in ClipWrap will retain Timecode, if your camera put it in the bitstream originally (not all cameras write timecode, particularly "consumer models")
Old January 23rd, 2011, 06:25 AM   #4
that helps
Thanks for the info. I'll check the site tomorrow.
So transcoding to ProRes does keep the timecode?
Marty Jenoff
www.focalpp.com
Old January 23rd, 2011, 08:10 AM   #5
Yes, as long as your camera actually recorded TC (nx5u, hmc150, etc)
Old January 23rd, 2011, 06:12 PM   #6
Right now I have the JVC GYHD200 and the Firestore MRHD100. Planning on getting the Sony NX 5 soon.
Marty Jenoff
www.focalpp.com
  You are here: DV Info Net > Apple / Mac Post Production Solutions > divergent media ScopeBox and ClipWrap
