Is there any way to prevent ClipWrap from combining M2T files? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > divergent media ScopeBox and ClipWrap
The official support forums for divergent media's ScopeBox (video monitoring and recorder) and ClipWrap (m2t to .mov re-wrap).
Old September 15th, 2009, 08:25 AM   #1
I have a project for which I manually encoded separate M2T files into AIC and then removed the pulldown in Cinema Tools. ClipWrap and Compressor provides a great way for me to update the project semi-automatically by having the source material in 10 bit ProRes 422, by simply replacing the original files. For this to work, ClipWrap needs to separately wrap sequential M2T files, but it seems to automatically combine them. I can't see a way to switch off this behavior.
Greg Quinn is offline   Reply With Quote
Old September 15th, 2009, 09:25 AM   #2
divergent media
Greg,
We autocombine clips with sequential numbers at the end, starting with 00 or 01, in the same directory. So you have a few options to thwart this - simply append another character to the end of the 00 and/or 01 clips in the folder, or move the files out of the folder.
so as an example:
test00.m2t
test01.m2t
test02.m2t ...wil be spanned.
whereas:
test00a.m2t
test01a.m2t
test02.m2t ...will not.
Hope this helps,
mike
Mike Woodworth
mike@divergentmedia.com
Mike Woodworth is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > divergent media ScopeBox and ClipWrap
