Not sure if this is the place or Premiere Pro.... at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old February 19th, 2007, 07:34 PM   #1
Hello,
I use Premiere Pro 1.5 and when I export, I use the adobe media encoder and export to MPEG - 2. I usually export at 6mb and duel render 16x9 NTSC.... Then I'm using Adobe Encore to put my DVD's together... through a timeline... Clients are emailing me saying that their discs aren't working... but they play fine on my computer and on a DVD player that I have here... any ideas? thanks!
Matthew Jackson is offline   Reply With Quote
Old March 10th, 2007, 10:51 PM   #2
Try exporting your Premiere sequence as a an AVI Movie file instead of using the encoder. I also use Premiere Pro 1.5 & Encore for my SD work, and have similar issues when using mpeg files in Encore.
Jeremy Clark is offline   Reply With Quote
Old March 12th, 2007, 11:24 AM   #3
Matthew, your encoding process is fine, you probably have some DVD compatibility issues. What blanks do you use, and what DVD burner? Older DVD players may have playback compatibility issues with some DVD-Rs and most DVD+Rs. All of us here at DVi have been throught this problem one time or another.
Personally I achieved zero complaints by using TDK DVD+Rs and bit-setting, Google around for how-to...
Ervin Farkas
www.AtlantaLegalVideo.com
Ervin Farkas is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
