FCE to iDVD squeeze at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old February 15th, 2007, 01:00 AM   #1
FCE to iDVD squeeze
Ok, I looked and looked and didn't find the answer to my question. I'm shooting with a HVR-A1U (Anamorphic 16:9). It seems that there is a way to export my edited movie so that iDVD will recognize it as a 16:9 file. There are so many different options to export and they jsut confuse me. I'm in Iraq (amry) and I'm trying to make a movie about the unit I'm in. Please help.
Josh Muehlendorf is offline   Reply With Quote
Old February 15th, 2007, 04:52 PM   #2
First of all, make sure your Sequence settings are set for 16:9
Then, when everything is finished, Export as Quicktime Movie (not Quicktime Conversion) Select Chapter Markers if you have them
You can select not Self-Contained as long as your FCE and iDVD are on the same system drive and you have the Scratch disk accesible to that drive
Download a free program called Anamorphasier. Put it on your desktop (Finder)
Take your exported movie and drop that onto Anamorphasizer. Drop the new file into iDVD, set up the project the way you want
If you have iDVD 5 or 6, I would create a Disc Image. When that is encoded, you can check it with Apple DVD Player to make sure everything is good. Then use Apple Disk Utility or Roxio Toast to burn the disc
Victor Kellar is offline   Reply With Quote
Old February 15th, 2007, 11:25 PM   #3
Tried that but still have problem
So I got the Anamorphasizor program and tried that. When I drop the file into the Ana... the viewing window opens up and runs through a little sequence then asks me to save the refernece file as... I don't have that option. Do I need to by QT7 to complete the proccess? Also, when I export the movie as a QT movie file, it plays like crap in QT. What's up with that. The footage looks great in FCE.
Old February 16th, 2007, 12:34 PM   #4
I had to upgrade to QT pro (approx $20) to get this to work.
After that, I was able to save the file and it appears to work (although I havent tried the DVD in all combinations of players/TVs yet)
There's also a Perl script you can run the disk image through that sets some more "bits" in the image for better 16:9 behavior -- I forget the name of it though.
Nick Ambrose is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
