Is option for +R burning useful? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old July 25th, 2006, 01:27 AM   #1
I might be buying a stand alone direct tape to DVD burner. Some burn DVD-R but not +R, others have the option to burn both. I can't think of any use for the +R format, except for one client I have who still uses an older model DVD player that only plays +R.
Have any of you come across situations where you need the option to burn +R format? If I buy one to accomodate this one client's need for a couple DVD+R transfers from tape, I'm trying to estimate if I might have other situations come up where I'd need to burn +R format.
I've already ordered a used burner that does not burn +R, so just wondering if I should get a second one for various formats.
This is just for those situations requiring direct tape to DVD. I use my computer, and DVD Studio Pro for making -R and +R DVDs from anything needing to be put on my hard drive for other work, editing, etc.
Chris Gorman is offline   Reply With Quote
Old July 30th, 2006, 01:45 AM   #2
From what I've reserached but not yet personally-verified, there is apparently a "book type" option available for the +R format that makes it more compatible than the -R format. This book-type field apparently makes the DVD+R appear to be a DVD-ROM, at least format-wise. Most people seem to gloss over the compatibility issue, but in the last year, I've had two situations in which DVD-Rs just don't read. Maximum compatibility is important to me.
Does your standalone DVD recorder set the book-type field ?
Gints Klimanis is offline   Reply With Quote
Old July 30th, 2006, 01:06 PM   #3
[QUOTE=...Does your standalone DVD recorder set the book-type field ?[/QUOTE]
The DVD standalone recorder I recently purchased does not burn +R, so it would not have "book type" option. My internal burner on my G5 can burn both +R or -R, so at least I can do the +R when I have the very rare request to do so (eg., thus far just one client whose set top player only plays +R).
+R's won't play in G4 Macs and earlier, so I haven't found from experience that they are more widely compatible if we include computer playability in the mix.
I see some (not all) current standalone DVD burners offering both +R and -R burning with the same unit and that made me wonder if there's a compelling reason for the +R that I may not have encountered yet.
So far all my DVD's have been burned to -R (Verbatim media) on my Mac via DVD Studio Pro, and so far, no compatibility issues - in fact I believe it played fine on a client's p.c.
However, I would not be surprised if I encounter some compatibility issues when I start using my recently purchased standalone recorder for certain simple projects, only because these burners are designed for home use.
Old July 31st, 2006, 09:24 AM   #4
There is no compelling reason to use one format over the other. A few older DVD players will only load DVDs that have the DVD-ROM booktype, which can only be set on a DVD+R disc. Still, the real-world compatibility of the DVD-R format is slightly above DVD+R discs. I don't know if it is enough of a difference to be concerned with, but that is how the situation is right now.
Christopher Lefchik is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
