Best export for You Tube at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old April 20th, 2006, 09:50 PM   #1
I have about 11 minutes of vacation video I shot in 30p I want to put on You Tube. I am using Adobe Premier Pro. What would be the best form of export?
Adam Bray is offline   Reply With Quote
Old April 24th, 2006, 05:01 PM   #2
i think that the limitations on input file size are 100 mb? i don't know if there is a limitation on how long the clip plays.
i used two-pass wmv encoding for the source file, keep the native frame size if possible, but make the overall file size as big as possible, i.e., the highest bitrate that will keep the file size under the youtube limits.
also take a look at vimeo.com, because they keep your input file linked online for people to see.
Dan Euritt is offline   Reply With Quote
Old May 13th, 2006, 02:35 PM   #3
Set your export at 320x240 and export with MPEG-4 codec and then mess with the quality settings so that your under the 100mb cap. You could also split up your video into two- 5min clips. This would give you better quality over all. That would be the way I'd do it.
Also check out what youtube says about exporting here: http://www.youtube.com/t/howto_makevideo
Good luck
Jack McTigue is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
