Tiger at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old February 23rd, 2006, 12:29 AM   #1
Tiger
Everything was going fine and then... I upgraded to TIGER. Now my IDVD3.0 doesn't work. I will burn my disc and the program will go through the motions, encode, etc. But, when it comes time to burn the program stops.
G. Lee Gordon is offline   Reply With Quote
Old February 23rd, 2006, 06:55 AM   #2
I had the same problem with iDVD 4. Very unreliable burns. I upgraded to 5 and that solved the problem. There are many new features in iDVD that you will appreciate. It is well worth the upgrade. Especially since you will be going from version 3 to 6. The other apps in iLife like iMovie are also improved in ways you will appreciate.
Old February 23rd, 2006, 08:01 AM   #3
I don't use iDVD, but it sounds like Ernest is giving you good advice. If you're determined to get version 3 to work under Tiger however, then the place to go would be Apple's tech support forum here: http://discussions.apple.com/forum.jspa?forumID=893
Old February 23rd, 2006, 07:05 PM   #4
When I burn with iDVD it is very unreliable so I just save it as a disk image and burn it with Toast. This happened with ver 4 and 5 in Panther and Tiger.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old February 23rd, 2006, 10:00 PM   #5
Workflow
Nathan, What is the workflow for doing that?
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
