Archiving final video, exporting each frame as PNG at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old June 20th, 2012, 04:23 PM   #1
So I gave this a try a like the results let me know if it's a good way or not so good.
I had a music video, and need to Archive, so Instead of making a video file, I exported the sequence as PNG files and the audio separate.
My plan is then to store files on a "cloud"
When I need it I can just download and bring into editing and export as needed.
Dave Morgan is offline   Reply With Quote
Old June 22nd, 2012, 10:38 AM   #2
Re: Archiving final video, exporting each frame as PNG
Depending on the actual png your editor makes, this is a lossless method, yes. However, more work to create, more files to manage, fragile to damage, and more work to reconstruct to video.
I may be missing something in your requirements, but more common archive methods would involve mastering to lossless or near-lossless video codecs. Such as DNxHD, Cineform, QT-Animation, MXF, etc.
Old June 22nd, 2012, 10:38 PM   #3
Conversion between BT709 and RGB color may not be completely lossless. For long term archival, I would suggest a SMTPE standard video format with multivendor support.
Eric Olson is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
