Batch encoding AC3s at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old September 7th, 2005, 01:52 PM   #1
Batch encoding AC3s
I use Procoder to convert files from DV to MPEG2. In the process, the audio channel is demultiplexed into a WAV file. Since Procoder can not create AC3 files, what is the easiest way of converting a folder of WAV files to AC3? I would hate to do it manually in Vegas (my editing application).
Emre Safak is offline   Reply With Quote
Old September 8th, 2005, 10:53 AM   #2
the wav files created by procoder typically have a limited bitrate, in order to fit on a dvd... depending on your application, they would probably not be suitable for use as an ac3 encoding source.
Dan Euritt is offline   Reply With Quote
Old September 8th, 2005, 05:14 PM   #3
Not at all; they are 16-bit PCM files. I should have indicated that I was working in stereo, not surround.
Old September 8th, 2005, 10:46 PM   #4
16-bit pcm at what bitrate, tho? and how does that bitrate compare to exporting an uncompressed wav file directly out of vegas?
Old September 9th, 2005, 06:18 AM   #5
16 bit at 48khz--unmodified sound from DV.
Old September 9th, 2005, 05:57 PM   #6
my bad, now i see what you are saying... i wonder if anyone has written a vegas script that batch-converts wav files to ac3? even if you had to buy it, the cost should be less than getting another ac3 encoder... sounds like a good question for the vegas forum.
Old October 6th, 2005, 05:06 AM   #7
Batch encoding PCM to AC3.
ReelDVD from Sonic ($250) will batch encode PCM files to AC3. There are other solutions (i.e. by Minetonka Audio) but as far as I know, more expensive.
Best regards.
Arnaldo
Arnaldo Paixao is offline   Reply With Quote
Old October 6th, 2005, 08:03 AM   #8
Thanks, for weighing in. I ended up using Belight.
Old October 6th, 2005, 08:05 AM   #9
Vegas->Tools->Scripting->Batch Render
Good Luck!
Serge Victorovich is offline   Reply With Quote
Old October 6th, 2005, 08:39 AM   #10
The "duh" moment...
Old October 6th, 2005, 02:28 PM   #11
the script was already included within the vegas software? lol... at least i was on the right track :-/
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
