Should I not use PCM? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old July 11th, 2005, 11:16 AM   #1
I have a feature film that I am about to recompress on DVD, so that a distributor can buy it. My question is, since PCM audio is better then AC3, should I use that instead of AC3? Thanks.
Glenn Gipson is offline   Reply With Quote
Old July 11th, 2005, 12:10 PM   #2
PCM audio will indeed have the best sound since it's uncompressed--identical to CD. BUT--the bitrate of PCM audio is a whopping 1411mbps instead of AC3s 160-320. That's almost a full thousand mbps more being dedicated to your audio (that must be taken away from video). If your movie is longer than about 75 minutes, using PCM audio will start to cut into the video quality. And truthfully, unless they're listening to the movie on a very expensive sound system, 99% of most people won't notice the difference between PCM and AC3.
-Brent
Brent Warwick is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
