Interlaced or Progressive Clip - How to Tell? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old April 23rd, 2005, 02:56 PM   #1
Hi. I'm new to digital video editing.
I currently use Adobe Premiere 6.02.
Is there a way to determine if a clip I'm working with is interlaced or progressive? Like I have a few .avi and .mpg files, and I want to know if they were filmed with a camera that had its settings on interlaced or progressive.
Matthew Weitz is offline   Reply With Quote
Old April 23rd, 2005, 04:02 PM   #2
Pick a section of the video that has some kind of fast motion, like a person running, a car passing, etc. Look at a few still frames in your NLE. If it's interlaced it should be very obvious, the edges of moving objects will have a comb effect where each of the 60i fields were captured. If it's true progressive you will see a blurred image in the moving parts, but the edges won't have the comb effect.
Have a look at this site for some examples: http://www.100fps.com/
Old April 24th, 2005, 03:19 PM   #3
Thanks.
What does NLE stand for?
Old April 24th, 2005, 07:48 PM   #4
From DVDictionary:
NLE - Non-Linear Editing
non-linear – computer-based editing which permits video clips, sound, edits or special effects to be removed, replaced, moved or modified at any time without changing or overwriting the original clip.
Brandon Greenlee
Brandon Greenlee is offline   Reply With Quote
Old April 24th, 2005, 08:00 PM   #5
In your case... Adobe Premiere 6.02 :-)
Old April 26th, 2005, 07:59 PM   #6
I think I got it. I used the following technique to deinterlace my clips (Adobe Premiere 6.02):
- I select the clips in my timeline.
- I choose Clip > Video Options > Field Options
- I select Always Deinterlace
- I click OK.
Do you know if there is a better way?
My end result is to get a good quality DVD.
Old April 26th, 2005, 09:14 PM   #7
Mathew,
Is there a particular reason you are deinterlacing your clips? You will lose quality by deinterlacing them. Usually the only reason you deinterlace video is to remove stuttering, or if you are striving for a "film look." But since you are removing one of the two fields from the video frame you will lose half of your resolution, which will be particularly apparent in interlaced (non-progressive) video.
If the video was filmed in progressive mode there is no need to deinterlace. It will already have the flicker associated with film.
Christopher Lefchik is offline   Reply With Quote
Old April 30th, 2005, 03:37 AM   #8
RED Code Chef
Christopher: the max resolution drop (in theory) is indeed 50%. HOWEVER,
with todays more advanced algorithms the drop shouldn't be so bad. To simply
proclaim you loose half the resolution is incorrect in my opinion.
(the following piece is not targeted to anyone specific, but just my feel
on some of the technical details people can get hung up on!)
Personally I don't even care, even if I did loose 50% resolution. I care how
the end result looks and how well the movie has been crafted together
(story, visuals, editing, music, sound effects, acting etc.), not how many
"lines" of resolution it has.
Rob Lohman, visuar@iname.com
Old April 30th, 2005, 07:40 AM   #9
Christopher: the max resolution drop (in theory) is indeed 50%. HOWEVER, with todays more advanced algorithms the drop shouldn't be so bad. To simply proclaim you loose half the resolution is incorrect in my opinion.
Well, that's good to know. But would that apply to the software he is using, Premiere 6? It's over five years old now.
I do know that from my own experience with a project I rendered out of After Effects (version 5.5, I believe), where my source was interlaced and my render settings were for deinterlaced, that there was a definite loss in quality. Sure, it had the filmic "flicker," but very unfilmic digital jagged edges.
Old April 30th, 2005, 01:18 PM   #10
Originally Posted by Christopher Lefchik
Mathew,
I was under the mistaken assumption that I wouldn't lose any quality.
Gotcha. Thanks.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
