Recording and Immediate VCD transfer at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old September 24th, 2003, 08:58 PM   #1
Hi,
I need to do a event whereby i am required to record the entire event and burn them to multiple copies of VCD immediately on the spot. so that it can be sold to the audience, is this possible?
Is there any solution for this?
ys
Yow Siang is offline   Reply With Quote
Old October 1st, 2003, 12:58 PM   #2
If your a mac user check out Roxios Toast Titanium 6. It has a function to import directly from a dv device to create vcds or svcds. I'm sure there a plenty of windows software that does the same, can't name any though.
I suppose recording directly to a computer would save you the transfer time from tape.
Benjamin Taft is offline   Reply With Quote
Old October 6th, 2003, 07:02 AM   #3
RED Code Chef
The problem is in the encoding time. If you bring a lapot you
can directly record on that and then encode it to VCD. There
are also devices that can be hooked up to PC's or laptops that
can store a stream directly in mpeg1/vcd which can then be
burned to VCD.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
