Change apsect ratio without reencoding ?
Hi,
I have two very important DVDs which were recorded in 16x9 (one PAL, one NTSC) but squeezed to 4:3 on the DVD. There is no chance that I can get these DVDs remastered for me. Is it possible to chance the aspect ratio flag on them without reencoding? Would I have to rebuild the menu? Which program should I use? Thanks for your help. |
Gints: are you on Mac or PC?
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
The simplest way I can see would be to use MPEG Streamclip to break the VOB files out to something you could re-encode and then author in DVD Studio Pro, choosing 16:9 letterbox as the display aspect on the track in question.
There may be a simpler solution but I'm at a loss. The other question is: since 16:9 SD is anamorphic by nature, can you just change a menu setting in your DVD player to display the content correctly? My very first 16:9 DVD was Peter Gabriel's Secret World and it took me about a week to figure out that Peter wasn't really THAT tall and that I had set up my DVD player wrong (which I only realized when I played a DVD that hadn't set the anamorphic flag right).
#5 | |
#6 |
After you run mpeg-streamclip to extract the VOB files, you can input the extracted file to DVD Architect. In DVDA, change the project properties to 16:9 widescreen and tell DVDA to build the database. At that point, DVDA will tell you whether it has to re-encode the data or not. Until you do that, it's hard to answer the question.
