Quicktime movie not playing on Canadian mac? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old December 10th, 2008, 08:21 PM   #1
Hi
I have a quicktime movie on my site that people can download (shot in PAL). It works fine on my computer. I did change it's size to 909 x 480 (it was 640 x 480 but I wanted it to play widescreen)
A person who downloaded it from Canada cannot play the .mov file, it appears pixelated. This person usually has no problems playing downloads.
I can't work this one out, could that change of image dimension affected playback? Or could this be a PAL/NTSC issue?
Mark Shea is offline   Reply With Quote
Old December 10th, 2008, 08:33 PM   #2
Well it's not NTSC/PAL, because computers don't care either way. The problem could be the way you saved it. Open the movie and push Command J. Check to see what type of encoder the video used, and make sure the Canadian has the right codec on his/her computer.
Edward Carlson is offline   Reply With Quote
Old December 10th, 2008, 09:05 PM   #3
thanks Edward
The video file is MPEG-4 saved as a .mov file
I originally saved the film (via standard compressor settings) as an MPEG-4 setting, then in quicktime, I changed the movie dimensions to widescreen, ie from 640x480 to 909x480 and the mp4 file became a .mov file.
Could this be the problem?
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
