How to use DV Video as menu background? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old August 27th, 2007, 12:25 PM   #1
How would I go about using a dv video clip as a background for a menu in DVD Studio Pro?
Vishad
Novus Productions - www.novusproductions.com -
Vishad Dewan is offline   Reply With Quote
Old August 27th, 2007, 12:54 PM   #2
Import the video clip into your assets in DVD Studio Pro. Then drag it from the assets list onto the menu background - a drop palette should show up, from which you should select "Set Background". That's all.
DVD Studio Pro will convert (if necessary) your input video to the MPEG-2. For best control over the result, you may want to use Compressor (or a similar tool) to convert your clip to MPEG-2 before importing the asset into DVD Studio.
- Martin
Martin Pauly
Martin Pauly is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
