#136 |
Re: New Canon Cinema EOS C200 and 200B
Correct me if I am wrong but we do get clean 10 bit 4:2:2 through hdmi for 1080P right?
It's just that we only get 8 bit 4:2:2 in 4K through hdmi. I am pretty confident that Canon will fix all these concerns in the formware update that's coming, it's very logical of them to do that. They are delaying giving that codecs to C200 until C300 replacement is released not to kill that line. Once C300 mkiii is released, they will give C200 10 bit 4:2:2 I am sure. |
#137 |
The C200 is 8-bit only unless you are shooting raw.
#138 |
Recently I've tested the camera in a presentation in Italy. I've found quite heavy to hold with one hand with the kit lens Canon EF 24-105mm f/4L IS II USM. The camera needs to be hold with two hands to be stabilized. Does anyone else find the camera heavy? I think with that zoom lens is more than 6.6 lbs (about 3.0 kg).
https://books.apple.com/us/book/be-i...o/id6442885092 |
#139 |
#140 |
I'm still using my old HPX170 with just one hand, as alternative maybe the Sony FS5 is a better camera to work with (I've read online that is very lightweight), I'm interested about EOS C200 but considering this problem I hope Sony will make a FS5 Mark II soon.
#141 |
#142 | |
#143 |
#144 |
I'll be surprised if the XF-AVC isn't 8-bit for the reasons Gary mentions. Canon definitely protects their own product lineup. That's why internal Cinema RAW Light is such a surprise as it totally breaks with Canons traditional marketing segmenting.
#145 | |
"However, with a future firmware update the EOS C200 will gain the ability to record both UltraHD and FullHD to Canon’s purpose built XF-AVC codec inside of an .MXF OP-1A wrapper. This format will allow for an abundance of metadata to be captured to the file" I would be willing to bet that the XF-AVC codec will be nearly identical to the MP4 option, just with the additional metadata that Canon cannot store in MP4. An 8-bit 4:2:2 XF-AVC codec already exists, it's in the XC10/15. However, an 8-bit 4:2:0 XF-AVC codec does not exist save for the low-bitrate proxy mode found in the C300/C700. That would need to be worked on and would explain why it's going to require a future firmware. Also, it may be possible that the external 10-bit recording modes in 2K/1080 disables internal recording. I can't find any info about that. I do know that all VFR modes will be in 8-bit, unlike the C300. |
#146 | |
#147 | |
Wide Range of Connectivity Options: Output Signal Configurations (During Shooting) Recording Type - MP4, 1920×1080 - HDMI 1920×1080, YCbCr 4:2:2, 10 bit (*3: Output will be YCbCr 4:2:2 8 bit when the recording mode is slow motion mode.). |
#148 | |
Shame on Canon for making a cine camera than can't be juggled by a newborn lemur. (emoji for laughing while typing)
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
#150 | |
