INTERCHANGEABLE-LENS CAMERAS α9 featuring full-frame stacked CMOS sensor
Equal Opportunity Offender
Re: INTERCHANGEABLE-LENS CAMERAS α9 featuring full-frame stacked CMOS sensor
No post? Only a link?
Andrew |
#3 | |
24.2MP Full-Frame Stacked CMOS Sensor BIONZ X Image Processor & Front-End LSI 693-Point AF System & 20 fps Shooting Blackout-Free Quad-VGA 3.7m-Dot OLED EVF Internal UHD 4K Video Recording 5-Axis SteadyShot INSIDE Stabilization 3.0" 1.44m-Dot Tilting Touchscreen LCD ISO 204,800, Silent Electronic Shutter Built-In Wi-Fi/Bluetooth, Dual SD Slots Integrated LAN and PC Sync Terminals Imaging Lens Mount Sony E-Mount Camera Format Full-Frame Pixels Actual: 28.3 Megapixel Effective: 24.2 Megapixel Max Resolution 24 MP: 6000 x 4000 Aspect Ratio 3:2, 16:9 Sensor Type / Size CMOS, 35.6 x 23.8 mm File Formats Still Images: JPEG, RAW Movies: AVCHD Ver. 2.0, MP4, MPEG-4 AVC/H.264, XAVC S Audio: AAC LC, AC3, Dolby Digital 2ch, Linear PCM Bit Depth 14-Bit Dust Reduction System Yes Memory Card Type SD SDHC SDXC Memory Stick Duo Image Stabilization Sensor-Shift, 5-Way AV Recording Video Recording Yes, NTSC/PAL Video Format 3840 x 2160p at 24, 25, 30 fps (100 Mbps XAVC S) 3840 x 2160p at 24, 25, 30 fps (60 Mbps XAVC S) 1920 x 1080p at 100, 120 fps (100 Mbps XAVC S) 1920 x 1080p at 100, 120 fps (60 Mbps XAVC S) 1920 x 1080p at 24, 25, 30, 50, 60 fps (50 Mbps XAVC S) 1920 x 1080p at 50, 60 fps (28 Mbps AVCHD) 1920 x 1080i at 50, 60 fps (24 Mbps AVCHD) 1920 x 1080i at 50, 60 fps (17 Mbps AVCHD) 1920 x 1080p at 24, 25 fps (24 Mbps AVCHD) 1920 x 1080p at 24, 25 fps (17 Mbps AVCHD) 1920 x 1080p at 50, 60 fps (28 Mbps MP4) 1920 x 1080p at 25, 30 fps (16 Mbps MP4) 1280 x 720p at 25, 30 fps (6 Mbps MP4) Aspect Ratio 16:9 Video Clip Length Not specified by manufacturer Audio Recording Built-In Mic: With Video (Stereo) Optional External Mic: With Video) Focus Control Focus Type Auto & Manual Focus Mode Continuous-Servo AF (C), Direct Manual Focus (DMF), Manual Focus (M), Single-servo AF (S) Autofocus Points Phase Detection: 693 Contrast Detection: 25 Viewfinder/Display Viewfinder Type Electronic Viewfinder Size 0.5" Viewfinder Pixel Count 3,686,400 Viewfinder Eye Point 23.00 mm Viewfinder Coverage 100% Viewfinder Magnification Approx. 0.78x Diopter Adjustment -4 to +3 m Display Screen 3" Rear Touchscreen Tilting LCD (1,440,000) Screen Coverage 100% Exposure Control ISO Sensitivity Auto, 100-51200 (Extended Mode: 50-204800) Shutter Type: Mechanical Speed: 30 - 1/8000 Second , Bulb Mode Type: Electronic Speed: 30 - 1/32000 Second in Bulb Mode Metering Method Center-Weighted Average Metering, Multi-Zone Metering, Spot Metering, Highlight Weighted Exposure Modes Modes: Aperture Priority, Auto, Manual, Program, Shutter Priority Metering Range: EV -3.0 - EV 20.0 Compensation: -5 EV to +5 EV (in 1/3 or 1/2 EV Steps) White Balance Modes Auto, Cloudy, Color Temperature, Custom, Daylight, Flash, Fluorescent (Cool White), Fluorescent (Day White), Fluorescent (Daylight), Fluorescent (Warm White), Incandescent, Shade, Underwater Continuous Shooting Up to 20 fps at 24.2 MP for up to 362 frames in JPEG format Up to 20 fps at 24.2 MP for up to 241 frames in raw format Up to 10 fps at 24.2 MP Up to 5 fps at 24.2 MP Up to 2.5 fps at 24.2 MP Flash Built-in Flash No Max Sync Speed 1 / 250 Second Flash Compensation -3 EV to +3 EV (in 1/3 or 1/2 EV steps) Dedicated Flash System P-TTL External Flash Connection Hot Shoe, PC Terminal Performance Self Timer 10 Seconds, 5 Seconds, 2 Seconds Connectivity 1/8" Headphone, 1/8" Microphone, HDMI D (Micro), Micro-USB, X-Sync Socket Wi-Fi Capable Yes Power Battery 1 x NP-FZ100 Rechargeable Lithium-Ion Battery Pack, 7.2 VDC, 2280 mAh Operating/Storage Temperature Operating 32 to 104°F (0 to 40°C) Physical Dimensions (WxHxD) 5.0 x 3.8 x 2.5" / 126.9 x 95.6 x 63.0 mm Weight 1.48 lb / 673 g |
But how do you feel about this Brian?
Andrew |
#5 |
I like the dual cards slots , fps and the new larger battery. I am going to check it out on Monday at NAB "Hands on"
#6 |
Pretty underwhelming when there's still crop factor in 30p (the frame rate I shoot for web content) and no 10bit HDMI.
I firmly believe they're way too scared to cannibalize the FS5 and FS7 to give the upgrades people want from the Alpha series. |
#7 | |
INTERCHANGEABLE-LENS *Still* CAMERA α9 featuring full-frame stacked CMOS sensor
We will see if they come up with a new A7 camera for people like you, who want to shoot video (10bit, UHD60p, whatever) from a smaller form-factor FF camera. I bet they do, with the new bigger battery and PDAF. |
#8 |
For still photography to have 20 fps with no viewfinder blackout and TOTALLY SILENT shooting with good battery life is amazing. A game-changer.
Not directed to video professionals. |
#9 |
Okay, so it looks like we have to wait longer for the A7S/A7R refreshes I guess.
#10 |
Jack:
Yes. But I will say that product upgrades are coming much faster from Sony than from Canon or Nikon, so maybe the wait won't be long. Also of interest is the fact that when new versions come out from Sony the old versions often remain "in the lineup" so prices for the previous versions don't tend to plummet. I bought another a6300 recently for $950 from B&H, after the a6500 was available. Not a lot less than what I paid for my first a6300 when the model first came out (about $1,000 if I remember correctly). |
#11 |
Here is an interesting accessory that folks might have missed:
NPAMQZ1K Multi Battery Adaptor Kit Charges 4 of the new "Z" batteries very quickly. Price is high but includes 2 batteries. Can also be mounted on a camera cage or tripod to connect to an A9 for using 4 batteries for extended on-tripod or in-cage use. The interesting part that you may not have heard is that this battery adapter kit supposedly works for using 4 of the new batteries to drive a camera that uses "W" batteries also (A7 series cameras). |
