JVC 4K Studio Camera | AK-UC3000 at DVinfo.net
Digital Video Industry News
Old March 1st, 2017, 04:56 PM   #1
Panasonic 4K Studio Camera | AK-UC3000
Key Features
•Supports 4K and HD acquisition simultaneously. HD output from camera (3G-SDI): 1080/59.94p, 50p, 59.94i, 50i, 29.97psF, 25psF, 23.98p over 59.94i
•Delivers high sense sensitivity of F10 (59.94Hz), F11 (50Hz)
•Equipped with a CAC (Chromatic Aberration Compensation) function capable of correcting even slight chromatic aberration at the lens periphery
•The DRS (Dynamic Range Stretch) function suppresses blocked shadows and blown highlights. Black gamma function for independent color settings in dark areas.
•The V-REC, F-REC function provides powerful support in digital cinema production.
•Features an internal digital extender (x2 magnification)
•12-axis color correction, detail, skin tone detail (two tone axis) and easy matrix adjustment
•An SD Memory Card can be used to set up data and firmware version.
•IP streaming (future option) and IP control is supported
•Advanced trunk functions such as 3x CCU to camera, plus 1x HD-SDI from Camera to CCU as well as a 1000Base-T LAN-Trunk
Image Device 1 x Large Format MOS sensor
Video Recording System NTSC/PAL
Lens Mount 2/3" Bayonet
Built-in Filters Neutral Density: Cap, Clear, 1/4, 1/16, 1/64
CC: 3200K, 4300K, 6300K, Cross, Diffusion
Video Format UHD 4K
P: 59.94/50/25/23.98
PsF: 29.97/25/23.98
HD
1080p: 59.94/50
1080i: 59.94/50/23.98p (over 59.94i)
1080PsF: 29.97/25/23.98
720p: 59.94/50
480i: 59.94
576i: 50
High Speed HD
1080p: 239.76/200 (requires optional CCU and recorder)
Sensitivity HIGH SENS
F10 (1080 59.94i)/F11 (1080/50i) @2000 lx, 3200K, 89.9% white
NORMAL
F6 (59.94 Hz)/F7 (50 Hz) @2000 lx, 3200K, 89.9% white
Gain HIGH SENS
−6, −3, 0, 3, 6, 9, 12, 15, 18, 21, 24, 27, 30, 33, 36
NORMAL
S/N Ratio 60 dB
Shutter Speed 59.94i/p
1/100, 1/120, 1/125, 1/250, 1/500, 1/1000, 1/1500, 1/2000
29.97p
1/60, 1/100, 1/120, 1/125, 1/250, 1/500, 1/1000, 1/1500, 1/2000
23.98p
1/48, 1/60, 1/100, 1/120, 1/125, 1/250, 1/500, 1/1000, 1/1500, 1/2000
50i/p
1/60, 1/100, 1/125, 1/250, 1/500, 1/1000, 1/1500, 1/2000
25p
1/50, 1/60, 1/100, 1/125, 1/250, 1/500, 1/1000, 1/1500, 1/2000
Connectors Video
3G/HD-SDI: 2 x BNC
Aux: 1 x BNC (HD Trunk or Prompter 2)
CCU: 1 x LEMO Connector
Genlock In/Prompter Out: 1 x BNC
Audio
Mic 1: 1 x 3-pin XLR (line/mic/+48)
Mic 2: x 3-pin XLR (line/mic/+48)
Front Mic: 3-pin XLR female (x1 Input)
Audio L/R: RCAx2 (x1 Output)
Earphone: 3.5mm Mini Jack (x1 Output)
PROMPT: BNC (x2 Output)
GENLOCK: BNC (x1 Input)
AUX: BNC (x1 Input/Output)
INCOM: 4-pin XLR (x2)
Lens: 12-pin
Power Requirements 12 VDC (during external power supply operation)
240 VAC (when CCU is connected)
Power Consumption 35 W (12 VDC supply/camera body only)
Environmental Operating Temperature: 14 to 113°F / -10 to 45°C (preheating required below 32°F / 0°C)
Storage Temperature: -4 to 140°F / -20 to 60°C Storage Humidity: Less than 85 %
Dimensions (WxHxD) 5.9 x 10.5 x 14.6" / 151.0 x 267.0 x 371.5 mm (excluding protrusions)
Weight 9.9 lb / 4.5 kg
AK-UC3000 4K Studio Camera
JVC 4K Studio Camera | AK-UC3000-0.jpg   JVC 4K Studio Camera | AK-UC3000-1.jpg
JVC 4K Studio Camera | AK-UC3000-5.jpg   JVC 4K Studio Camera | AK-UC3000-2.jpg
Old March 2nd, 2017, 04:26 AM   #2
Re: JVC 4K Studio Camera | AK-UC3000
Hi Brian,
you say in your text ..."new JVC studio camera".
The photos attached with your contribution show cameras with "Panasonic" written on it.
What is the truth?
Joachim
Joachim Claus is offline   Reply With Quote
Old March 2nd, 2017, 05:24 AM   #3
The link goes to a Panasonic camera.
*** http://www.vimeo.com/chipgallo ***
Chip Gallo is offline   Reply With Quote
Old March 2nd, 2017, 08:41 AM   #4
Re: PANASONIC 4K Studio Camera | AK-UC3000
Originally Posted by Joachim Claus View Post
Hi Brian,
What is the truth?
Joachim
MY BAD it is Panasonic I got the broche yesterday. I can not get back into my post to edit the title.
Brian Rhodes is offline   Reply
