Tascam DR701D With HDMI trigger, no more pressing rec twice! at DVinfo.net
Digital Video Industry News
Old November 18th, 2015, 05:10 PM   #1
http://static.bhphoto.com/images/ima...00_1189478.jpg
http://www.bhphotovideo.com/c/product/1189478-REG/tascam_dr_701d_linear_pcm_recorder.html
Record 4 Channels + Stereo Mix
4 XLR/TRS Inputs with Phantom Power
Dual Built-In Omnidirectional Mics
Stereo 3.5mm In for Stereo Mic
3.5mm Camera In/Out
BNC In for Sync to LTC
HDMI In Can Receive Timecode From Camera
HDMI Out Can Send Audio & Incoming Video
Records Up to 24-Bit/192kHz
Mount to DSLR or Tripod
Ted Ramasola
http://ramasolaproductions.com
Old November 20th, 2015, 12:08 PM   #2
Contributor
Re: Tascam DR701D With HDMI trigger, no more pressing rec twice!
Really nice. Several can be daisy-chained through HDMI for higher channel counts, good. Hope the preamps are better though. My DR-70D is all right especially if used with high output microphones but my MOTU Traveler mk3 and Roland R-88 preamps are far quieter.
In such a small form factor it is probably not easy to cram 4 preamps together will all the other electronics, noise will not only be generated in the op-amp chips but will also be coming from nearby circuits.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old November 21st, 2015, 02:55 PM   #3
If you need "pro" preamps, you are not going to get a "recorder + pro preamp" for under $3K (ie. Sound Devices). This is a GREAT unit as a bit dumper. Use pro preamps in front of it when needed. When you don't need pro preamps, use the ones included. A pro portable 2 channel preamp is going to cost you $1K alone.
Mics and preamps cost money.. the bit recorder is the cheap part. This does 4 channels at 24/192. And has nice level meters. Also has a 5/6 channel mixdown.. onto easy to move around SD cards.
I wish they would take out those crappy internal front mics and make the unit smaller.
Derek McCabe is offline   Reply With Quote
Old November 21st, 2015, 08:08 PM   #4
Absolutely. Never gonna use those mics. I'd trade them any day for better micpres. Or... for lower prices. But I really don't want the built in mics. For anything.
Bruce Watson is offline   Reply
