#1 | |
Canon announces VIXIA Mini personal HD camcorder
Canon Announces New VIXIA Mini Personal HD Camcorder at DV Info Net Manufacturer's product page located at: http://usa.canon.com/cusa/consumer/p...ers/vixia_mini More info from manufacturer located at: http://usa.canon.com/cusa/consumer/s...lay/vixia_mini |
Re: Canon announces VIXIA Mini personal HD camcorder
"Mechanical Shutter for the recording of moving subjects with little distortion."
Does this mean no more jello-cam? |
Rolling shutter is caused by staggered reading with no mechanical shutter. A mechanical shutter could/should solve it. :)
That said, if the read-reset time of the sensor is extreme, then a mechanical shutter might only work well for fast shutter times. In other words, the interval in which all lines would be able to accept light could be very small if each line working with staggered timing. So, a reasonably fast CMOS sensor coupled with a mechanical shutter should do the trick.
Jon Fairhurst |
#5 |
Due to it's form, size, where the lens is placed and the abiliity to wirelessly switch from wideangle to tele by wifi I expect it to be mounted as a flying camera soon after it's release...
