Magic Lantern unlocks Canon 5D to shoot 14 bit raw via liveview - Page 8 at DVinfo.net
Digital Video Industry News
Old June 23rd, 2013, 02:39 AM   #106
Re: Magic Lantern unlocks Canon 5D to shoot 14 bit raw via liveview
You mean 78MB/s not Mb/s.
Trouble is though you still need to get up to around 2.3k/2.4k of bayer pixels to achieve HD resolution and that means around 70% more data than your recording at the moment. 1880x864 of raw bayer data falls well short of HD.
Does'nt matter if your competing image is coming out of same box (5d2). if you can grade and uprez to a much more pleasing image, you are ahead of the game.
Chris J. Barcellos
Old June 26th, 2013, 01:58 AM   #107
Ok, for those with a 5D2 using NB after jun 16th and are having problems in crop mode, specifically pinkish cast image with low black levels.
a.d. has made a new fix which you can download here: https://bitbucket.org/a_d_/laboratory/wiki/Home
I tested this repeatedly in several resolutions in crop mode and pink cast is gone.
Take note that this fix will cause some "bad pixel" problems in SOME cameras in raw video mode. Like this one;
RAW recording 5D2 recent NB produces 'bad pixels' (not with .H264 output)
This does not show up when using h264 video.
My camera however don't have bad pixel issues with raw video so I use the fix provided by a.d.
Ted Ramasola
http://ramasolaproductions.com
Old June 27th, 2013, 10:09 PM   #108
Significant improvement with Jun 27 build ML raw video
With build dated Jun 27, ML developers have made significant progress allocating memory and increasing significantly the recording duration for RAW video.
On the 5D mkII new higher resolutions are now capable of recording continuously with a 1000x cf card. Performance have also improved on slower cards such as 600X.
Below are test results based on a 1000x lexar. FPS=23.976
At 1X
Resolution-------Number of frames
1872 x 1054-------1058
1872 x 1012-------4686
1872 x 936--------continuous
1872 x 850--------continuous
1856 x 1044-------2378
1856 x 928--------continuous
1728 x 972--------continuous
1472 x 1104-------continuous
Crop Mode 3X (5x magnify)
2144 x 1076-------371
2144 x 1072-------370
2144 x 974--------947
1920 x 1076-------1326
1856 x 1044-------continuous
1728 x 972---------continuous
Ted Ramasola
Old June 27th, 2013, 11:32 PM   #109
I know they're probably wanting to get things to a certain point before they branch out to different models. But is there some insider talk on how this might work with some of the crop sensor range?
Just curious if they've tried it for even a moment.
Murray Christian is offline   Reply With Quote
Old June 27th, 2013, 11:36 PM   #110
Murray,
Most crop sensors that can run ML can do Raw video though limited. What particular models are you interested in, I'll try to retrieve some information from ML and transfer it here.
EDIT:
Among the crop sensor canons, the old 50D is performing well, I saw testers getting 1584x1058 and 1584x894 continuous and recording 2000х1080 in crop mode.
Ted Ramasola
Old June 28th, 2013, 11:02 AM   #111
Cheers Ted
I've got a 60D myself. I can think of a few 7D owners who'd be curious too (it's also interesting to see if its weird architecture throws up any more problems for them in this area)
Old June 28th, 2013, 12:39 PM   #112
There is some progress with the 60D.
The 7D is in more dire straits due to the dual digic. Its running in alpha ML but sadly no raw video.
I myself have a 7D and as days goes by I'm thinking of letting it go or giving it to my son. :)
Ted Ramasola
Old June 28th, 2013, 03:03 PM   #113
for 30P recording with 5D2
For 5D2 users looking at how the 30P recording has improved with jun 27 "small hacks" build.
Resolutions --No of frames@30P
1872 x 1054 --237
1872 x 1012 --312
1872 x 936 ---460
1872 x 850 ---770
1856 x 1044 --287
1856 x 928 ---489
1728 x 972 ---650
1728 x 864 ---3338
1472 x 1104 --701
1472 x 828 ---continuous
1600 x 900 ---continuous
Crop mode 3x
2144 x 1076 --132
2144 x 1072 --158
2144 x 974 ---213
1920 x 1076 --235
1856 x 1044 --294
1728 x 972 ---476
The highest res for continuous recording has indeed increased. Previous NB it was only at 1472x828 for 30P Now its at 1600x900.
Ted Ramasola
Old July 16th, 2013, 08:26 PM   #114
Magic Lantern Improves 5D Mark III Dynamic Range to 14 Stops
5DMk3 : Video
7D : Stills only
Dual ISO - massive dynamic range improvement for 5D3 and 7D
~ J o h n B e n t o n
http://johnbenton.tv
John Benton is offline   Reply With Quote
Old July 25th, 2013, 12:29 PM   #115
FOR MKII DO NOT USE a128gig 1000x or 1050x UDMA7 CF card for Magic Lantern
Just want to update 5D mkII users that for now DO NOT USE a128gig 1000x or 1050x UDMA7 CF card for Magic Lantern.
Tests I have been doing with techsupport from Komputerbay shows us that the 5DmkII
can accept the fast cards ONLY WHEN USING CANON FIRMWARE and for shooting stills and H264 .MOV files.
BUT the card CANNOT BE USE TO UPDATE FIRMWARE, even the firmware from Canon can't be "seen" by the 5D mkII
also MAGIC LANTERN FIRMWARE CANNOT BE "SEEN" BY THE 5dMKII, even if you use EOScard to make it bootable.
So far we are doing the tests using Komputerbay 128 gig 1000x and 1050x cf cards,
If you are using a 128 gig on the mkII + Magic Lantern please share if its 1000x or less, also if its UDMA7 or less.
Ted Ramasola
Old August 10th, 2013, 12:13 AM   #116
Re: Magic Lantern Improves 5D Mark III Dynamic Range to 14 Stops
5DMk3 : Video
7D : Stills only
New update:
Dual ISO module has been ported to the 5DmkII. Photo mode.
Ted Ramasola
Old August 10th, 2013, 09:20 AM   #117
Nice ! Thanks for the update
J
Old August 10th, 2013, 02:24 PM   #118
7D now recording RAW video continuously no longer in bursts. :)
Testing first versions of raw_rec module now.
Ted Ramasola
Ted Ramasola is offline   Reply
