Lightworks release date - Page 30 at DVinfo.net
Digital Video Industry News
Old September 12th, 2024, 07:35 AM   #436
Re: Lightworks release date
I don't know when last tested Lightworks, but there has been quite a few changes over the years.
It sounds like you used the classical Lightworks layout, which is now called the flexible layout. The default layout is the fixed layout, which can be customised to personal taste, but not on the fly as can be done with the flexible layout.
In Lightworks there's usually more than one way of doing things and the same applies to how you import media.
Old October 29th, 2024, 11:27 AM   #437
LWKS have released Lightworks V2025.1 (This was renamed from V2024.1 because of the late release) and is now available to download.
https://forum.lwks.com/threads/new-l...wnload.251982/
There as been a lot of under the hood changes to improve performance, expand the export options, adding further masking features and allowing the creation of your own custom effects, plus improvements to the user interface.
The existing NewBlue effects bundle will continue to work with V2025.1
Old February 12th, 2025, 06:12 AM   #438
There are regular updates with fixes, which can be found here: https://forum.lwks.com/forums/product-releases.19/
Old November 26th, 2025, 07:38 AM   #439
The new Lightworks V2025.2 release is now available to download.
Changes include:
On top of UI/UX improvements, LWKS have reworked the playback and transcoding (export) engine to be able to build a better, faster and more flexible system going forward.
New Layouts - Edit, Effects, Audio and Export - for more intuitive workflows.
New Keyboard Shortcuts
New “Unified” Viewer - in the new Edit layout
Filters have been renamed ‘Collections’
New Tags feature (available in Collections)
Further information can be found here: https://forum.lwks.com/threads/light...9/#post-290228
Brian Drysdale is offline   Reply
