Changing BLUE to BLACK? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old July 10th, 2007, 04:58 PM   #1
I'll be shooting a scene in which I need a BLACK passenger van. Unfortunately, nobody seems to rent black passenger vans in my price range.
I've been able to rent a DARK BLUE one and I'm wondering how best to shoot the scene to make the "dark blue" seem "blacker."
I'm shooting on the Canon XH A1 (24f), outdoors during daylight hours. I have Adobe Premiere Pro 2, After Effects, and Magic Bullet 2.1.
Is there anyway to locally tweak the color in the shot? Or must I affect the entire image to get what I want?
Any advice would really be appreciated.
Rene
Rene Brar is offline   Reply With Quote
Old July 10th, 2007, 06:58 PM   #2
I haven't played around with it too much yet, but PPro 2 has secondary color correction... So, you should be able to select and tweak just the colors of the van without really affecting colors in the rest of the scene. You could also fake it if you get creative with your lighting- or if you shoot the dark blue van at night under street lamps.
Shawn McCalip is offline   Reply With Quote
Old July 11th, 2007, 09:13 AM   #3
if your bg is a different enough hue, isolation/color correction on the blue would be really easy. if that is not the case, you would have some masking/roto work which, depending on the length of the shot and fg elements, would be of varying complexity.
Adam Clark
Trick Digital
www.trickdigital.com
Adam Clark is offline   Reply With Quote
Old July 12th, 2007, 09:40 AM   #4
just off the cuff, spill suppressor comes to mind in the keying tools.
it will allow you to choose that particular blue and suppress it to black.
might be a quick answer.
Ger Griffin is offline   Reply With Quote
Old July 13th, 2007, 02:42 AM   #5
It would be easier to make the blue another color like red or green, because you could use a hue shift. To make it black however you will have to affect lightness and saturation, since the normally lit areas of a black van will be dark grey, the shadow areas black and the highlights will be light gray/white.
Steven Fokkinga is offline   Reply With Quote
Old July 18th, 2007, 01:00 AM   #6
Hi Rene,
Try "change color" in After Effects, you select with the color picker wich color you want to change and dial the change. Also you can try change to color that is slightly different. Both are standards in AE. Of course youŽll want to avoid the same color of the van in other parts of the frame.
Martin Chab is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
