720x576 to 640x480 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 4th, 2007, 02:08 PM   #1
720x576 to 640x480
Hi guys,
I will be making some 720x576 clips and wanted to know the best way to then change them to 640x480 will be?
how different will the picture be when its rendered at 640x480? will it be the same but just obviously smaller?
i don't have the time to test this out and would like to know if anyone has done such a thing?
thanks very much :)
im using AE also! forgot to mention :)
www.basicproduction.co.uk
Liam Carlin is offline   Reply With Quote
Old June 4th, 2007, 03:49 PM   #2
There are a few ways to go about doing this, but here's a couple if you're interested...
1- Create a 640 X 480 comp in AE, import your 720X576 footage and scale it down until it fits in the frame, render, and you're done!
2- In your your rendering queue, click on the "lossless" options, and then punch in your new resolution in the panel that pops up. If you keep your proportions constrained, you might not get down to 640X480 exactly, but you can get as close as you can and render that way.
Someone else might have a better/faster/mega/super way of doing this, but that's my 2 cents. Good Luck!
Shawn McCalip is offline   Reply With Quote
Old June 4th, 2007, 03:58 PM   #3
Thanks for that Shawn! i thought it was a lot more complicated and had gone through the first process you mentioned and thought this cant be right.
Thanks again :)
Liam
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
