Exporting HVX footage to After Effects at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 1st, 2007, 01:38 PM   #1
I cannot figure this out! Every time I export a seq from FCS as native(720p24) the resulting QT is 1280x270(1.33) instead of 960x720(1.33). So when I make a new comp in AE I set it to DVCPRO HD 720 but the exported QT never fits.
Regards
_Eric
Eric Santos is offline   Reply With Quote
Old June 12th, 2007, 01:57 PM   #2
This may not be right, but before you render out of FCS, change the footage's Pixel Aspect Ratio to 1.0 instead of 1.33.
Then when you bring it into AE, simply drag the footage over the Make New Comp button, and it will make a new comp to the exact same settings as your footage.
Hope it helps.
SB
Steven Bills is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
