Wavy heat-distortion effect at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 14th, 2007, 01:11 PM   #1
I'd like to hear from anyone who has tried to produce an effect like the heated-air-distortion that you see rising from hot surfaces in Adobe (AE and/or PP). I've got all sorts of footage on green screen that will be virtually-set on a hot tarmac.
Any suggestions for creating the appearance of a hot surface heating the air above it?
thanks in advance,
andy
Andrew J Morin is offline   Reply With Quote
Old May 14th, 2007, 02:18 PM   #2
Try the Ripple Effect
Try This:
In After Effects, create an Adjustment layer over the footage/photo of your hot tarmac. Draw a mask using the pen tool- or a box to see things quickly- and put that mask near your horizon line. Feather the edges on it, and then apply the Ripple effect.
Personally, I put the center of the ripple somewhere out of frame, off to the side.
For the other settings, use a light touch... Try width settings between 30 and 60, wave height between 1 and 3, and then start off with a slower speed somewhere between 2 and 4. You can also animate the speed to achieve more of a random effect to simulate reality.
Hopefully my "poor man's tutorial" helps out. Good Luck!
Shawn McCalip is offline   Reply With Quote
Old May 14th, 2007, 02:58 PM   #3
Originally Posted by Shawn McCalip View Post
...Hopefully my "poor man's tutorial" helps out. Good Luck!
That's exactly the kind of quicky, starting-point suggestion I was looking for!
Andy (still open to other clever suggestions)
Old May 15th, 2007, 08:05 AM   #4
If the Ripple effect doesn't work for you, try the Wave Warp effect.
Frank Hardie is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
