Auto Setup in Magic Bullet won't work!!!! at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 9th, 2007, 05:42 AM   #1
I've done what the manual said. Turned Separate fields off, set the frame rate to 23.976, but when I click "auto setup", nothing happens!
It says this in the "messages" column:
"NTCS to 24p* Magic bullet is now configured etc..."
How do I fix it?
Mel Abdo is offline   Reply With Quote
Old May 9th, 2007, 10:01 AM   #2
If it is saying it is 'now configured' then you have set it up. Are you sure you have written the message correctly? If it is saying it unable to setup then I suggest you have a look at what the reolution of your footage is and how AE is interpreting it.
I think you may have it set up correctly if your message is correct though...
Steve Benn is offline   Reply With Quote
Old May 9th, 2007, 01:41 PM   #3
Yes, but it still says "Please click the auto setup button in the effects panel" in the preview window!
Old May 18th, 2007, 10:02 AM   #4
Is the composition set to 23.976 - and the video left at 29.97 ? Other than that - or an odd non standard resolution, I have no idea. I would suggest contacting Redgiant directly - I am sure they will be able to help you out.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
