Transparent in Motion at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old March 7th, 2007, 03:55 PM   #1
I've tried numerous different options within motion to make the background transparent, but every time it overlays the background with black in final cut. I've selected transparent in the top window, I've brought down the background opacity to 0%. I'm stuck.
Anyone out there that can provide some info?
Thanks for your time!
Josh Woll
Josh Woll is offline   Reply With Quote
Old March 7th, 2007, 04:03 PM   #2
There's a couple things that could be going on:
1-You're exporting your Motion project to a codec that doesn't support alpha channels
2-FCP, by default doesn't show transparency as a checkerboard background. By default, it's just a black hole.
I never have any problems because I always just bring my Motion project files directly into the timeline. FCP then does all the processing and rendering.
My Work: nateweaver.net
Old March 8th, 2007, 09:23 AM   #3
Nate, your brilliant. I suppose for some reason when I export the file in motion, it puts that background into it. I don't why I have been doing that, because I would be double rendering and exporting the file through final cut anyways. Thanks for your help.
Take care,
Josh
Old March 8th, 2007, 10:34 AM   #4
If you're gonna do the export thing, you have to choose a codec that supports alpha channel, like animation codec, or there's one or two others that I can't remember at the moment.
There's also a toggle in the Motion export as well, I believe.
Just doing the project file directly in FCP is the best way. You can use a Motion project file directly in ANY Quicktime application as well...like After Effects. It's pretty dope.
Nate Weaver is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
