What is most amout RAM After effects can utilze? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old March 4th, 2007, 11:06 PM   #1
I do A lot of After Effects work. I want the most amout of Ram that After effects can utilize. I understand premiere can only use up to 3GB. Same for AFX?
Tyson X
Tyson Persall is offline   Reply With Quote
Old March 5th, 2007, 07:38 PM   #2
There's no hard and fast answer to this.
For example, under Windows XP with 4GB of RAM installed (the maximum that XP will be stable with), XP will only make 2GB available to other 32 bit programs. This 2GB will be shared between any 32 bit programs running at the time. Therefore, under XP, Premiere will be limited to 2GB, as well.
I can't give you details on how other operating systems handle RAM access, but I'm sure most would be less restrictive than XP.
Frank Hardie is offline   Reply With Quote
Old March 6th, 2007, 08:41 AM   #3
Follow this thread for information on how to allow After Effects to use more than 2 Gb of memory!
http://www.dvinfo.net/conf/showthrea...ht=effects+ram
Juan
Juan Oropeza is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
