After Effects 35mm dvinfo tutorial at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old November 19th, 2006, 10:34 PM   #1
I currently edited files that I shot on dvcam mode, at 60i and want to change the file to 24fps rather than standard 30fps ntsc
I tried the simulating 24p tutorial on the dvinfo site(http://dvinfo.net/articles/filmlook/broadway1.php), however when I rendered the file and exported it, the video was more like slow motion, is this how 24 frames is supposed to be? Is there any other possible way to simulate 24p without magic bullet, nor a dvx100 camera?
James Johanson is offline   Reply With Quote
Old November 21st, 2006, 01:59 PM   #2
I see no point. Invest your energy elsewhere. Lighting, writing, directing, etc.
Emre Safak is offline   Reply With Quote
Old November 21st, 2006, 02:57 PM   #3
Are you sure you didn't miss a step?
You might look here for a freeware method:
http://aqua-web.dyndns.org/avisynth_24p.php
If you can afford $145, you should look at DVFilm Maker:
http://www.dvfilm.com/maker/index.htm
John McManimie is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
