Pre-made HD graphics. at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old September 21st, 2006, 06:19 AM   #1
I'm considering to mix SD and HDV material. I was thinking of maybe putting the SD footage in a frame on a HD graphic instead of upsizing it. Does anyone know a place I can buy and download pre-made HD graphics, interfaces and stuff like that?
Kristian Indrehus is offline   Reply With Quote
Old September 21st, 2006, 07:55 AM   #2
I can generate HD graphics/BGs for you if you would like, just drop me a PM with the kind of thing you would like and I can see what I can do.
Lee Wilson is offline   Reply With Quote
Old September 21st, 2006, 06:31 PM   #3
Plays didge when lubricated
Digital Juice do them too...not sure about downloads although they have some freebie Hd downloads. I think you just have to sign up for their e-newsletter. www.digitaljuice.com
Paul Hackett is offline   Reply With Quote
Old September 22nd, 2006, 01:29 AM   #4
Thanks. I'll check it out.
Lee, do you have a site were I can see your work?
Old September 25th, 2006, 06:32 PM   #5
If you've got access to After Effects, check out www.videocopilot.net
Andrew Kramer has made some HD backgrounds that are completely customizable in After Effects, but you do need the program to use them.
Cal Johnson is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
