After Effects 7.0 Image Degradation Problem at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old September 18th, 2006, 08:41 PM   #1
I have been using After Effects for a long time to do my visual effects and have always noticed the same problem. The image seems to lose its antialisis(?) when it is imported into AE. By this I mean you seem to lose detail with diagonal lines, they become pixilated. The settings I use for my project are the presets for wide screen DV footage (720X480 29.97FPS and 1.2 wide pixels) so I assume it should work and look great, but it doesn’t. Is there anything I’m overlooking? I’m going to try to add a link to two screen shots I made. Ignore the bleach bypass and digital filter I added (they didn’t cause it).
Before After Effects
http://i32.photobucket.com/albums/d1...elberg/raw.jpg
After After Effects
http://i32.photobucket.com/albums/d1...berg/final.jpg
Alan James is offline   Reply With Quote
Old September 18th, 2006, 08:50 PM   #2
It could be deinterlacing or resolution reduction. Check your settings. Try testing footage with a lot of motion.
Emre Safak is offline   Reply With Quote
Old September 18th, 2006, 09:02 PM   #3
Got it! It was seperating the fields and only using the lower. Because its a progressive image I was only getting half the vertical resolution. Thanx for the super fast response.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
