Parallax Slow Motion effect at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old September 2nd, 2013, 01:11 AM   #1
Hello everybody,
I'm curious how you accomplish the effect seen in 30" to 53" in this video. A kind of slow motion parallax and also like a sideways dolly move.
Anybody know?
Urban Skargren is offline   Reply With Quote
Old October 7th, 2013, 09:59 AM   #2
Re: Parallax Slow Motion effect
I wouldn't think this is done in post. Easy to get a shot like this in camera.
Looks like it was done with a high frame rate cam, on a slider/dolly and simply moved really quickly while shooting high frame rates. FS700 mounted securely on a long dolly/slider would get this shot no problem.
Automotive Multimedia
Justin Molush is offline   Reply With Quote
Old October 7th, 2013, 03:02 PM   #3
This might be a "bullet time" effect. Or it might just be a high speed camera on a dolly.
Post production is not an afterthought!
www.arniepix.com
Arnie Schlissel is offline   Reply With Quote
Old October 7th, 2013, 03:13 PM   #4
I thought they took high speed photos (many per second with high shutter spead), put them in After Effects and separated the different depth layers and had these layers move independently to increase parallax.
Old October 8th, 2013, 10:43 AM   #5
Entirely possible.
However, given that this was shot outside, during the daytime, and there is nothing in the slow mo shot to tell me otherwise, Im pretty sure they skipped the headache of rotoing that from greenscreen and simply used a medium/medium-telephoto (something like a 50mm or 85mm) with high frame rate and very fast dolly/slider movement.
I very often use a jib with medium length lenses and the longer your telephoto, the more exaggerated the parallax effect you get natively in camera. Turning up the frame rates and whipping my crane hard allows me to get "normal" speed camera movements while the BG appears slow. Same principle applies to a slider.
Old October 13th, 2013, 07:52 PM   #6
Wow that video was impressive! Yeah I think it could have been a high FPS camera on a dolly. Have to try it out to know if that works.
Firewerkz Films SGP
Sean Seah is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
